Question about Epson Stylus CX4400 All-In-One InkJet Printer
This is a new printer. I printed 5 pages of black and now the printer displays "out of ink" ... continuous red light. What can I do. I bought the same printer Sept. 2007 and used it for only a
This is a new printer, purchased in Sept. '08. I printed about 5-10 81/2 X 11 pages in b/w. The next time I turned my printer on, the continuous red light came on indicating "out of ink". Last Sept. I had bought a new printer of this exact kind and it worked for about 6 months and the same thing happened only after using it for about 100 or so sheets of this same size. I didn't use it any more. I now need a printer and bought this one new, thinking maybe the other one was just had been a bad make or something. Can you help me?
    Problem Solver:
  • 15 Answers
Assume all the ink cartridges are original because a fake one may give that type of warning. I would open the printer and check that the plastic sheet covering the cartridge opening has been taken away. I would take out each cartridge and put it back. If the problem persists, it is likely that the ink in the tank had been dried out (very old stock) or the printer ink sensor is busted. It should still be under warranty I hope.
Posted on Oct 19, 2008
New ink cartridge only last less than two weeks after printing less than 30 pages
I had that model and the same experience. I kept buying ink until I realized I could have nearly bought the printer for nearly the same cost as ink refills, black and color. I also had an HP. Same thing. I finally bought the Kodak 3250. The ads about ink costs was so correct. Many more pages are printed before the "need ink" message is displayed. Buying ink online saves even more.
Mar 27, 2012 | Canon PIXMA MP150 All-In-One InkJet...
MY hp c6380 printer will only print in color. Any black text will be very lightly printed so you cannot read it or not printed at all.
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Aug 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
My black ink does not work. I have put 2 new
please clean the heads of your black cartridge also the scanner or sensor for cartridges this can cause to black cartridge not to print.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wont print black just gray! new HP!
Ensure first that is not a setting problem, check that the printer is not in Economy or Fast print mode, and try to print with a different resolution settings.
If printer prints fading black on all conditions and this is not a settings problem, then the printhead is defective.
In that case have the printer replaced.
Mar 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer replaced with black cartridge, and doesnt print
Hello sir; did you remove the tape sealed on the black cartridge, make sure your cartridge is OEM not GENERIC.
Feb 03, 2009 | HP Photosmart C6100 All-In-One Printer
Wont print in black.
hi,
check the ink level of the color cartridges also. because to print in black it will use some color also.
if everything is ok try this
> unplug the usb cable from the printer
> click on "start-->control panel--> printers and faxes".
> select all the printer icons which is related to your priter and delete it.
> once that is done, plug the usb cable back to the printer.
> wait for few minutes while it installs the driver automatically.
> if done, try printing in black from varius applications like notepad, wordpad, ms word etc.
> if o go, you may have to service the unit as you have already tried with 3 different black cartridges.
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 3210 Printer
Quit printing black
did anyone ever solve this issue? We have the same printer and can't get the Dam thing to just acknowledge black ink only.. When any of the color cartridges are low the stupid printer won't allow us to proceed printing in black until we replace the cartridge that is low..$#@**&^*$#
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Wont print in black
Check if the cartridge is stuck or dirty.
Dec 07, 2007 | HP Photosmart 3210 Printer
Epson Stylus CX4400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
