Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Envision 17" LCD display will not stay on
My relatively new Envision 17" LCD display will not stay on. It turns on and then, without displaying, turns off in about 5 seconds and repeats this process over and over. The CCFL backlight flickers just as the display is power cycling. I have isolated the problem to the power supply, which is internal to the monitor. By pulling the CCFL backlight power plugs I can get the monitor to turn on and off and stay on as expected (of course I can't see anything). THere are 2 CCFL tubes in the monitor and the power cycling happens with either one connected to the power supply. Since it's unlikely both tubes went bad at once, I suspect the power supply rather than the CCFL tubes. THe manufacturer wants more for the board than I paid for the monitor so it's either fix the power supply or dump the display. I've looked at a number of power supply boards on ebay and they all seem to have the same configuration with an inverter section for each CCFL - again, since my problem happens when either CCFL is connected, I am suspicious that the problem lies in the part of the power supply that controls the CCFL inverters. Anyone understand these things to the point they can offer some assistance?
  • 4 more comments
  • waymirjr Jan 25, 2008
    Hi I have the same problem. When the power button on the monitor is pushed the desktop is viewed for one second and then goes to black.
  • Anonymous Feb 01, 2008
    I have the same problem (as waymir jr.) "When the power button on the monitor is pushed the desktop is viewed for one second and then goes to black."
    I didn't realize until just now that this is a monitor problem and not a computer problem. I have been trying to fix the 'computer' problem forever with no luck. Everything on my monitor looked normal (green power LED on constantly, meaning that the monitor is getting signal from the video card and that the monitor power is on).
    When I powered up my computer, I would see the monitor's LED go from yellow to green, and on the monitor I would see the POST information for about 1 second, then disappear. I would keep 'resetting' (rebooting) the computer (thinking it's a computer problem) until the POST message would display for the correct amount of time, and then the Windows XP loading screen came up. After that it would be fine and I could use the computer/monitor. But I noticed that when the OS went to screensaver mode (after a few minutes of non-use) when I came back and moved the mouse, I would see the desktop (or whatever I was last doing) on the monitor for 1 second, and then the monitor would go blank. Then, if I shut the monitor off (by pressing the power button) and turned it on again, I would see the desktop again for 1 second and then the screen would go blank. I did this a few times and eventually the monitor stayed on and I could do work. At that point, I realized it was a monitor problem.
  • chris5555 Feb 01, 2008
    a monitor problem.
  • billjog Mar 04, 2008
    my monitor comes on but then immediately goes off. I suspect the innvertor but where can I get one? Bill G
  • healykp Aug 16, 2008
    My problem is identical. Backlight flashes on for a fraction of a second and repeats endlessly. I can hold a flashlight up to the display and I can see that it is still on between flashes! So, the entire unit is not cycling just the section powering the backlight inverter(s). I found 2 bad capacitors in the power supply and replaced them. No good. Any help would be appreciated. Thanx, KPH
  • tkkr Oct 07, 2008
    My monitor displays for 2 seconds and then goes dark. I power it off and back on and the dipsplay works for 2 seconds and goes dark. I plugged it into the second computer and the monitor did the same thing. For the 2 seconds the monitor displays a picture it looks great. What can the problem be?
Seems the N-Channel MOSFET switch in the power supply is the culprit. NTE does not list a replacement part for this, so a sub is necessary (any N-Channel 600V MOSFET in same TO220F case should suffice). I have to look one up for mine.
Posted on Mar 25, 2009
If this were my monitor, I would keep an eye on eBay for the same or similar model, except with a cracked screen or some drastic physical damage that would allow you to get the monitor really cheap, then cannibalize the power supply (provided the new one powers up okay). Definitely cheaper than ordering parts from a manufacturer.
Posted on Jun 21, 2006
SOURCE:
Picture won't display after a few seconds
this is either the flourescent bulbs are going out or the power supply has bad capactors on it. You might open it up and look at the power supply board for capacitors with their ends that look like they are "erupting" on the ends.. this means they need to be replaced.
May 13, 2014 | Envision EN-7410 17" Flat Panel LCD...
Turning the power on causes the screen to display ENVISION for approx. 1sec.and it goes out and stays out. Switching a display signal on through an A-B switch gives approx. a 1sec. display time that does...
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
Jun 11, 2009 | Envision EN-7220 17" Flat Panel LCD...
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
Envision 9410e monitor only display for a second.
Hi...there,
It's seems you got unlucky...your backlight inverter got burnt...Need to replaced a new one or repaired it. Caps it a fuse look like a tiny battery that power the backlight...
Nov 30, 2008 | Envision EN-7100e 17" Flat Panel LCD...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
LCD Benq FP937s+
This is an Inverter related issue on the Inverter board.
Feb 23, 2008 | Relisys RLT1720 17" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
454 people viewed this question
Top Envision Computers & Internet Experts
Kelly Blanc
Kelly Blanc
Level 1 Expert
Paul Bade
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
