Question about PNY Quadro FX 4000 SDI, (256 MB) PCI Express Graphic Card
PNY FX4000 SDI, AGP - Windows 2000 - Systems KEEPS rebooting...
I have just installed a PNY FX4000 SDI, AGP card into my Windows 2000 PC. Windows loaded fine, just after I installed the card, but after loading the drivers the systems wants to reboot. After rebooting, Windows starts to load BUT then I get a glimpse of the bluescreen of death, again just a glimpse, then the system rebooted - repeatedly. Now, after I've shut down the system completely, the screen is just black-no signal. Any suggestions will be greatly appreciated!
Roger
X1550 256mb dd1 agp driver
Hello the driver can be downloaded here:
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx
Click to download the Option 1 - Full Software Suite.
You will need to reboot your windows system, when the install is done.
Good luck
Feb 24, 2013 | Power Color POWERCOLOR ATI RADEON VC X1550...
How do i upgrade my PNY-NVidia gt-6200 Agp GForce 256Mb 3D card
First of all, you have to get a card that is an AGP. These are still out the, search online, that is your best option. Once you order a new card, it's simple, pull out the old video card, carefully. And then once the card is removed, you can carefully put your new one in.
Once you have the card installed physically, you will need to install the drivers for it, when you are in windows. If you card didn't come with a drivers cd, you can go to the manufactors website and find your particular card, download the driver. After its finished downloading, choose to install it, and then follow the instructions provided my the installation.
May 06, 2011 | Microsoft Computers & Internet
I did a re-install on my computer (an old dell dimension 2350) and I have a PNY GeForce FX 5200 and for some reason afterwards the computer no longer will allow the monitor to use the GFX card only the...
you need the correct driver for it which you can get from the geforce website. you also need to enter the setup (bios) and make sure it is starting with your video card (pci) instead of the onboard video.
Mar 01, 2011 | PNY GeForce FX 5200, (128 MB) AGP Graphic...
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
PNY geforce 6600 ddr 256mb agp/ with Asrock k7s41 motherboard When i install PNY geforce 6600, sis 741 chip on mobo seem to be still running. have changed to AGP from PCI in bios, card will...
PSU 250W usually isn`t good with GF6600 (like and high) videocards. Strongly recommended 350W and high for this configuration (and "350W" - not only numbers in model - for really QUALITY PSUs).
Sep 25, 2007 | Asrock K7S41 Motherboard
PNY Quadro FX 4000 SDI, (256 MB) PCI Express Graphic Card Logo
104 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
