Question about Pitney Bowes C180 Copier
C180 copier error code E7
I have I C180 copier that was working great at my house but when I moved it to my office and set it up. I have a E7 error code. Also my sort tray will not slide up and down when the copier is turned on.
  • Nike Merritt May 11, 2010
    E7 is definitely sorter code. The sorters for these are tricky. aon all sorters make sure the bins are in the correct slots on the sides, especially after a move. Any resistamce will stop it completely. If all else fails, you can disconnecy yje sorter and just use the copier. Do you have a small sorter that hangs on the side? How many bins?
  • 149 Answers
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
Posted on Feb 24, 2010
How do i fix error code E7 16 on my ar5516 sharp copier
E7-16 means abnormality in function of Laser unit. All you can do is reseat connectors, disassemble Laser unit and clean optical system. Otherwise replacement is required.
Apr 24, 2017 | Sharp Office Equipment & Supplies
What causes error code E7-14 on a Sharp MX-M363N?
Haven't come across that one before:
Trouble content
Detail SCU
Cause SCU PWB trouble.
Check & Remedy Check the SCU PWB.
Replace the SCU PWB.
You could try resetting the machine:
START (Copy mode)
Press the Program key.
Press the asterisk (*) key.
Press the clear key.
enter 14, execute
Jan 20, 2017 | Sharp Mx-M363n Copier, Printer & Scanner...
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
May 19, 2014 | Bladez Exercise & Fitness
Sharp AL-1651CS Color Copier, error e7-11
Is the lamp lighting when it codes out? If no, replace light source #1 (the whole moving part of the scanner).
Jan 06, 2012 | Sharp AL-1651CS Color Copier
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error: E7 -01
the sorter bins are binding when they try to move. check for alignment
Sep 17, 2010 | Pitney Bowes C180 Copier
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
Pitney Bowes C180
There should be another set of flashing number after the E7.
There should be another 2 digit code.
This will help determine where the problem is located.
The E7 error code is a problem with either your automatic Doc Feeder or the the sorter if there is one installed.
If there is a sorter/collater, then also let me know if it has a stapling unit installed or not.
Jan 24, 2008 | Office Equipment & Supplies
133 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
