Question about Kenmore 9297x Top Load Stacked Washer / Dryer
Kenmore All I One Washer Dryer, (20-25 Years Old).
The relay for the dryer heater was shorted out by a dime. I need to get either that relay, (Essex 8127), or equivalent. ware_eddie@yahoo.com.
  • 725 Answers
Many web sites that will sell you a relay also check a local appliance part store..
Posted on Oct 19, 2008
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
We have the dryer stacked on top of the washer and though we have always cleaned the screen, the dryer doesn't dry very well now. it's 5 years old now.
its likley to be one of your heaters has burned out, it has two one for low heat one for high heat on low only one works,,, both work for high heat
Oct 25, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
My Kenmore Dryer turns on and then goes off on it's own
by the time you purchase a part it would be almost half of what a new one would cost. Check for any clogs that may be in a drain and try playing with the dryer door latch. These things could also cause this problem. But a 12 year old washer could just be a motor wearing out from age.
Feb 11, 2009 | Kenmore 62602 Electric Dryer
No heat from he4 kenmore dryer
did you check the outlet got 240 volts? if you did and your not getting that at the heater it could be the board or the motor if the switch in the motor is bad it wont send power have you found the tech sheet? that will give you how to test it but if you think swapping parts is OK then you need to go buy a multimeter so you can find the faulty part
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
My kenmore electric dryer, model 110.66812692 turns off after
Hello dstanton56,
You may have a temp sensor that is failing and causing the heater element power to be disabled. Some dryers have multiple temp sensors and if any of them electrically open ( either from an overtemp condition or because they are on the verge of failing) then that will disable power to the relay that provides AC to the heater element. Bottom Line: could be the thermal sensors or the relay or even the heater element itself. A 4 year old dryer that has been used a fair amount of the time ( such as yours ) will probably start showing these kinds of symptoms. Let me know if you are up to removing the panel and troubleshooting these components and I can help walk you thru that.. Otherwise.. you may have to have it serviced by a technician.
Regards,
Rick
Nov 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 9297x Top Load Stacked Washer / Dryer Logo
Sal DeAngelo
fordexpert
Ed Mac
