Question about LG Refrigerators
Cold air circulating fan
The freezer at the bottom is cold and the fridge on top is warm.
I think the fan is not circulating the cold air but I dont know where it is located to check it.
  • Anonymous Mar 16, 2014
    Where is the blower located inside of the tfx20p... The compressed is working but no circulation inside of the freezer or fridge
    President:
  • 1,462 Answers
Behind back panel inside freezer. take back panel off
Posted on Oct 20, 2008
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Frost in freezer fridge warm
Sounds like the circulating fan behind the rear panel inside the freezer section is starting to go bad, This problem is very hard to diagnose because the fan still spins but at a much lower rate than needed to circulate chilled air thru the freezer and the frig. The minimum cost for parts and labor is around $300.00.
Aug 02, 2009 | Maytag MFD2561HE Bottom Freezer French...
Freezer freezes, fridge below will not cool
if your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Nov 17, 2008 | Kenmore Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Nov 12, 2007 | Kenmore 72912 / 72914 / 72919 Bottom...
Refrigerators Logo
206 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
