Philips DVDR610 DVD Recorder
Problem for Philips DVDR610 DVD Recorder
Dvdr610
By majaruskova2 on Oct 19, 2008
need help to start work my dvd with new remout
Comments:
Oct 19, 2008
- thanks i have the instructions for the universal remote it is responding to it but wont let me set the time or press ok do i need the original remote
Oct 19, 2008
- i am still waiting for any info thanks
am still
Solution #1
posted on Oct 19, 2008
Not Helpful)
Neoklassic1
Rank: Wiz
Rating: 82%, 73 votes
If you just purchase a new universal remote control. You need the manual that came with remote. Inside you should be able to find your brand of DVD player and the codes to activate it. Since all Universal Remotes are different there's no set procedure that will work for all of them. You will need the manual and go through each step to set up correctly. If you don't have or misplaced manual, you might need to contact manufacturer to either replace manual or receive the codes. Good Luck
Comments:
Oct 20, 2008
- Ok if you are going to ask for help, maybe you should elaborate on what you actually need so you can get proper help................''need help to start work my dvd with new remout.'' Doesn't explain anything..Good luck
Was this helpful?
Yes
No
Popular Solutions for Philips DVDR610 DVD Recorder
Questions and Unsolved Problems for Philips DVDR610 DVD Recorder
Do you recommend Philips DVDR610 DVD Recorder?
Answer
Answer
I need the remote code for dvdr 615 so I can program my DirecTV remote to communicate with it.
Answer
when i turn it on it says "startup" for a few seconds, then goes off. then a few seconds... (More)
Answer
dvd discs burnt on philips dvdr3460 [divx] will not play on other players.do i need to finaliz ? if... (More)
Answer
I got a dvd recorder610 but i am not able to work with this device because i have no idea how to... (More)
Answer
When i turn it on, it says 'startup' for a few seconds and then nothing. I can't open it to put a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips DVDR610 DVD Recorder:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
