Question about Samsung MU3250W Microwave Oven
Sumsung MU3250W shut down
All of a sudden, wegn using the microwave, after 3 seconds it shuts down and the timer pad reads 8888. I then reset the clock and try again. If works for 3 seconds and shuts down. I turned off the power (at the breaker) for 10 minutes to try to reset the internal breaker. Still happens. Light and truntable work until it shuts down.
  • 2 more comments
  • garymbg Oct 19, 2008
    Unit is far from under warranty, but it must be foxed as the kitchen was designed around this unit and there is not other with the exact dimensions to fit. Therefore, I need to fix this
    I rewired whole kitchen before reno. Everything is properly grounded
    Checked door swithces and interlock
    Thanks -- in the end, I think it was humidity. It is working again just fine
  • 84 Answers
The problem is your magnetron tube is leaking RF. The mag tube comes on 2-3 seconds after you hit start, and the RF interfears with the board and shuts it down. Drop the front of the control panel down and watch, it wont happen.. Get a new mag tube put in and you'll be good to go.
Posted on Oct 19, 2008
    Scholar:
  • 84 Answers
Your control bord is short circuit problem change it
    Genius:
  • 1,550 Answers
It can be a door switch issue or a bad door switch mount.
It can also be due to damper .
  • SAM ANDERSON Oct 19, 2008
    The magnetron is overheating and the magnetron thermostat is opening up the power to cool .
    You need to have check over this .
    Brigadier General:
  • 3,614 Answers
Most likely the problem is a bad control board which probably has some traces micro cracked, but before you replace it I would recommend to check how good the range is grounded.
  • Samsung Master
  • 13,433 Answers
It is most likely a internal protection mechanism, if your wave is still covered by the warranty suggest you contact your dealer for repairs.
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Panasonic Microwave suddenly won't cook.
    Your microwave is detecting an internal shot and shutting down, Most likely due to a faulty Magnetron which is not a part that is worth replacing due to the cost of the part and the decrease in cost of new microwaves.
    Mar 06, 2012 | Panasonic Microwave Ovens
    MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
    This is magnetron-related.
    See
    this FixYa solution (solution #2) even though your model number is different.
    Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I unlock the key pad? The display shows locked and I don't know how it locked.
    Here you go.
    The Child Lock shuts down the control panel pads to prevent
    unintended use of the microwave oven.
    When the control is locked, only the Vent Fan and Light pads will
    function.
    To Lock/Unlock Control: The microwave oven and Timer must
    be off. Touch and hold START for 5 seconds until 2 tones sound
    and a lock icon appears on the display. Repeat to unlock and
    remove the lock icon from display.
    May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    Time count down on microwave oven
    Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
    Aug 25, 2009 | Maytag MMV4205 Microwave Oven
    Microwave wont start but timer counts 3 secs and shuts off
    Check the door latch mechanism the black nylon door catch may be broken.
    Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
    Nothing on my touch pad works
    My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
    after a few seconds.
    We brought it in July or August
    Debbie
    Mar 27, 2009 | Maytag MMV1153A Microwave Oven
    GE Spacesaver XL 1650 microwave shuts off after a few seconds
    this would be the digital control board that would need to be replaced
    Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Samsung MU3250W Shut down
    It could have been steam or humidity.
    If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
    Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
    When in doubt feel for air flow through the vents.
    Good luck.
    Oct 19, 2008 | Samsung MU3250W Microwave Oven
    Timer Shuts off after 5 seconds
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
    Let us know if the hard reset doen't fix it.
    Please write back with more details if you need further help.
    We appreciate your thoughtful rating of our answer.
    Nov 18, 2007 | GE JES1289SK Microwave Oven
    Samsung MU3250W Microwave Oven Logo
    342 people viewed this question
    Top Samsung Microwave Ovens Experts
    William Miller
    William Miller
    Henry  Thomas
    Henry Thomas
    Gerry Harvey
    Gerry Harvey
    Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
