Question about LG X-Note LM50 Notebook
Lg r 405 will not recognize wireless signal from lynksys wrt350n
I recently setup a new wireless router, a Linksys wrt350n and all periphs except my notebook will recognize it.
    Scholar:
  • 70 Answers
You need to connect a hardwire from your router to laptop notebook and see if you can connect to internet. If you can that means router is working properly. Now you should have received a setup disk with the router. You will need to run the disk to set up the wireless capabilities. Such as security settings that will allow you to access internet, but secure it from unauthorized usage. If you don't have a disk but is still able to access internet wired directly to router go to www.linksys.com. Under technical support tab look for Easylink Home Networking Tools. You will need to download application. Then open it up after it's downloaded and it will configure the router for you. It will allow you to name your network, provide you with security access codes, and also allow your notebook to automatically detect your router everytime you log on for internet access. Good Luck
Posted on Oct 19, 2008
    Scholar:
  • 94 Answers
Hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Our access point linksys model wrt350nver2 doesnt connect with our loptops
Make sure that you have all the correct wireless settings of your network.
You can also try creating a new wireless network and then connect to the new wireless network.
Connect the computer to the router and open the setup page. Change the wireless network name and then connect to the new wireless network on your laptop.
If that is also not working then you can try to reset linksys router and reconfigure it.
Sep 23, 2011 | Linksys WRT350N Wireless Router
Hello there. i have two lynksys WAG200G routers.
Are you wanting to expand the ports available to your internet connection or simply increase the coverage area. I suppose it's the same in the end. What would you like to accomplish?
Jun 14, 2010 | Linksys WAG200G Router
I lost my wrt350n rooter password. Are there way ...
think you need to reset the router and reconfigure it . There is a small reset button on the router. Press and hold it for 30 seconds. Remember if you reset the router, you will lose all the router settings and you will need to reconfigure it . Follow link to reset linksys router
May 21, 2010 | Linksys WRT350N Wireless Router
Linksys WRT350N Connection Problem and Power Light Flashing.
Are you trying to set up the router ? For this you don't need to use Linksys Easy link advisor. Easy links advisor has bugs in it. If you call the Linksys tech support, they will also not help you for Easy link advisor. All you need to do is, open the router set up page and check the settings of the router. according to the settings on the router, you can connect the new device to the network. is ther any computer connected to the router? use that cmputer to open the router set up page.
Apr 06, 2010 | Linksys WRT350N Wireless Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Lynksis Wireless Router does not stay connected to the Internet.
I suggest checking the documentation of your linksys router in the linksys site. Get the manual and that would tell you how to set it up. Regarding the router being broken, it is possible. Are you wired or wireless to the router?
Jul 22, 2009 | Linksys Wireless-G WRTP54G Router
3800HGV-B and LinkSys Dual-Band Wireless-N USB Network Adapter
Because the linksys is talking about SecureEasySetup which most lynksys routers use. The 2wire 3800HGV-B button is not a SecureEasySetup button.
Mar 18, 2009 | 2wire (1000-400108-001) Router
I had to buy a new lynksys wireless router and I have to put it on the computer so I can use it correctly.
Since this is a new router you can just run the setup CD that came with the router and follow the step by step procedure there , but if the setup CD failed you can just contact Linksys tech support so a tech can wlak you through with the process on how to manually configure the router, this is the number 800-3267114 they are open 24/7...
Dec 03, 2008 | Linksys Wireless-G Broadband Router
LG X-Note LM50 Notebook Logo
283 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
