Question about HP PSC 1610v All-in-One Printer
Margins How to change printer default margins
  • rachel_a Jan 19, 2009
    It's not the page margins on the document, it's the printer margins. The printer will not print past about 20mm from bottom of page - regardless of what the page margins are set to.
    Problem Solver:
  • 10 Answers
You can only change the margins on the paper by using your windows program when you first start to write your paper. I believe it would fall under either edit of tools. It's been a while for me but that may help
Posted on Nov 15, 2008
I am giving the margine in Adobe Pagemaker in legal size paper left 2", Right 1", top2" & bottom 2" but printer is print on paper from top only half inch margin
Did you remember to change the paper type in the printer settings to legal, before printing? If not it will use the default, usually letter size.
Feb 27, 2015 | HP LaserJet M1005 MFP Printer
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
How to manually change default page margin for Panasonic DP-2330?
oh my go to printer properties, right click, go to page set up change the settings hit APPLY BAM there ya go
Mar 07, 2017 | Panasonic Workio DP-2330 Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
What are the default margins for this printer
Hello
The Marin option is not the printer option it is the application option what you are using like MS Word has default Margins are shown as under cmptrlink_12.jpg
like this all applications has their own margin options, hope this helps if so do rate the solution
Jan 05, 2011 | HP DeskJet 920c InkJet Printer
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
Canon MP480 printer prints enlarged text and shifts page margin
hi. have you tried print from other pc. ? if still the same issue maybe is a internal problem with your printer
Apr 30, 2017 | Canon MP140 PHOTO AIO All-In-One InkJet...
I am not able to print the portion from exactly start of the page of ms word document, why? Not able to show it in print preview??
Hello and Welcome to FixYa!
The portion within the Margins can only be printed, lessen the top margin at bit.
I remember the top margin for default is 1', change it to 0.5' or 0.6'
In Office < 2007 (Margins are in File > Page Setup)
In Office 2007 (Margins are in Page Layout > Margins > Set it to Narrow)
Note: If you printer is non-Laser (I mean if it is Ink-Jet) Do not make the margins too less, the printer won't be able to print it.
Sep 27, 2009 | Microsoft Office Word 2007 Upgrade Version...
Paper is out of range Samsung printer when printing in word it always says paper out of range
Check your default margins on the printer. Open Word, open a document, click on File then Print. When the printer's printing window opens, click on properties. You should now be able to see the Margins or a Margins tab in the window. Check you margin settings. If they are below .5" in any of the 4 margin settings then you printer probably cannot print the document. Change the settings and save them as the default settings.
You may also try updating your printer driver, too, depending on how old your printer is.
You should also check the settings for the paper type you are using. If it is not the normal 8.5" X 11", then you will need to change this setting as well.
Hope this answers your problem.
Sep 04, 2009 | Office Equipment & Supplies
HP PSC 1610v All-in-One Printer Logo
Ben Johnson
