Question about Maytag Washing Machines
MAYTAG NEPTUNE ERROR CODE NF - Maytag Washing Machines
  • 725 Answers
NF is a NO fill..
1 check that the water is turned on.
2 check the water pressure
3 check the nose filter screens
4 check the water valve is opening
5 check the conection on the water valve to the control.
6 replace control board
Posted on Oct 19, 2008
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on May 13, 2007
ngfam1
  • 639 Answers
SOURCE: neptune washer-- nf, code and
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Any time you have codes you just have to bite the bullet and call factory service!!!!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
SOURCE: MAYTAG NEPTUNE ERROR CODE OE
I have a Samsung Washer and the water would just keep pouring in and not stop. Eventually the OE error code would show and I would have to stop and turn off the water.
Thanks so much. You can fix this problem yourself. There are only two screws holding this part on. It is easy. I bought my part here.
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4044218
Nobody stocked the part for the samsung but I found out that the Whirlpool part was exactly the same.
Posted on Sep 25, 2009
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune nf error
My guess is that something got disturbed in the plug when you pulled it off/put it back on. You turn it to "hot wash" and it does nothing? Does it buzz?
Jan 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL model #FAV6800AWW
The error code nf is supposed to mean that NO water is coming in. Sounds to me like the water is coming in but the water level pressure sensor tube is either kinked or broken or the sensor itself is faulty. Before doing anything else you should disconnect the tube and blow it out - see if there is a tear or pinhole in it. If the tube is o.k. then you probably need a new sensor. In either case, I would really like to hear from you directly by Email at abehol@yahoo.com .
Apr 02, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Open Questions:
Maytag Centennial: Not starting, maybe lid lock issue? How to install new magnetic lid latch? then is replacing lid lock next or could it be something entirely different? Help, please, and THANK YOU! I have a Maytag Centennial washer MVWC450XW3 that quit working last week. In hindsight, I could see that there had been a history of "stuff" going on with the washer, all around the lid lock;i.e. - last time it worked I had to select a couple of different cycles before it finally started. SO Far, I have tried to get the diagnostic codes but failed a bit at that. I THINK that I was getting an F5E1 error. I was however at least able to access the diagnostic menu, and notice TWO things: No matter what, the Lid Locked LED never comes on, ever. Next thing I notice is when I do a short cycle diagnostically, it never agitates or spins. It fills various temp water, does not agitate, then it seems to suck the water back out. IN the end, I ordered just the magnetic part of the lid lock (the part that is actually on the lid) because I could see mine was rusted all the way away, but am not too sure how to put it on. Therefore I just put it in the slot where it would go if I had installed it. Incidentally II asked my ma if she had noticed anything going on with the washer and she said No at first but then with prompting (she's 81) allowed that she had indeed noticed something wrong with the lid shutting so she had cleaned out that "little hole"{ very well and oiled it to make sure it was working. So again my two main questions are: How to install the lid latch, do I need to take out all of the screws around the glass? and Should I next move on to buying a lid lock part or could it be something entirely different?
Mar 21, 2017 | Maytag Washing Machines
Washing Machines Logo
2,636 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
