Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
How much play in rear pulley
I have a 3 year old Kenmore Elite HE3, model #42822 201. A little while ago it developed a ticking noise when the drum turned. I could not track it down then, but it is getting worse. When I took the belt off it seemed to to away, I also noticed a lot of play in the rear pulley at the back of the drum. How much is OK? Is that pulley supposed to have play or is it supposed to be tight? Thanks in advance. Scott
  • sporkles Feb 19, 2008
    Is anyone sure about the five-year warrantee on bearings? Replacing the pulley, belt, and pulley nut won't help?
  • mtsagaser Dec 22, 2008
    I have a kenmore elite h3 44832 with the same problem. I opened the back cover and saw a LOT of belt dust - because the pulley was moving during rotation. The symptom was a lot of noise in high spin. Is it the pulley or the bearing? If it is the bearing, do i have to replace the basket? Rear tub? Thanks in advance!!
    President:
  • 878 Answers
Scott, the pulley should be tight, no play, Check to see if one of spokes are cracked on the pulley. I do believe that you have a 5 year warranty on the bearings on this machine, parts only. It's a huge job to replace the bearings on this model. Give Sears a call to see if they will cover the parts. You will need the rear tub and bearing kit...Good luck
Posted on Jun 21, 2006
SOURCE:
Dryer beeps running
Hello Biff
You should the the following.
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
Best Regards
Neciforo Llanto
Sep 21, 2013 | Kenmore Dryers
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Load noise during spin cycle also metal wire sticking out of drum inside washer. This is a Kenmore elite he3 5 years old
i think it might be fixable but u should go to O' Riley's Auto Parts and ask someone there.
Nov 23, 2012 | Washing Machines
I have a Kenmore Elite He3 model 110.44832. I ran
Open the top and inspect the damper mechanisms that control drum motion in various directions. There may be broken pieces, or just something out of position. Hope this helps!
Jul 01, 2010 | Washing Machines
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Makes loud noise after 10-12 minutes after start
there are 4 drum rollers thats support the drum and have bronze bushings in them that could be worn and making nose.
also the units belt does have an idler pulley with a bearing in it too.
any of these could make a noise when they get warmed up or hot. its not likely that they are worn out already. i would guess you dryer is only a few years old so unless you use it 3-4 times a day it would be unusual. it also could be the drive motor, as there have been some of these that have failed. if you can take it apart and see if any of the bearings i mentioned are tight, then replace that part.
if not and you suspect the motor, then call sears and get the "service smart plan"
it will cover any of the repairs as changing the motor will cost about 250 bucks if you have to pay to have it done and the plan will be cheaper then that.
Mar 13, 2010 | Dryers
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
209 people viewed this question
Sal De
fordexpert
yobo007
yobo007
