Question about Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax
How do you set the fax machine up to my desktop
I am trying to set the fax machine up to my desktop so that i can use it as a printer
    Genius:
  • 2,120 Answers
If it is a modern fax machines with a USB or printer port, you just need the driver disk which should have come with your machine. You can also download it from the manufacturer
Posted on Oct 19, 2008
Instructions for fax 2820
for drivers click here
let me know if you need anything else.
Jul 24, 2008 | Brother IntelliFax-2820 Laser Fax
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
Hp printer 6313 all in have problem for fax. error number 351
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
Nov 24, 2009 | HP FAX 1250 Fax Machine (Black)
How do you set up the rings for a lexmark fax machine lexmark 6570
Setting Auto Answer to on
From the desktop, double-click the Productivity Studio icon.
2 From the Welcome Screen, click Fax History and Settings.
3 From the “I Want To” menu, click Adjust speed dial list and other fax settings.
4 Click the Ringing and Answering tab.
5 From the Auto Answer drop-down list, select On.
6 Click OK to save the setting.
The Auto Answer light on the control panel comes on. When the number of rings you set is detected, the printer
automatically receives the incoming fax.
Hope this fully answers your question. Best of luck.
Greg
Jun 26, 2009 | Office Equipment & Supplies
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Unable to send & receive the Fax
Try calling your fax machine with a cell phone to see if the fax answers. If not, check that the phone wire to the fax is plugged into the LINE socket, NOT THE PHONE SOCKET on the fax machine. Next, go to the MENU on the fax.You may have to check or change one or more of the following settings by trial-and error to fix the problem. BEFORE YOU CHANGE ANY SETTING, WRITE DOWN OR PRINT OUT THE ORIGINAL SETTINGS. In the MENU, find FAX SETTINGS, FAX SET-UP, or INITIAL SETUP settings. Try changing one or more of the following: PULSE/TONE, RECEIVE MODE, SEND MODE, RING DELAY, RING TIME, OVERSEAS MODE, etc.
Nov 26, 2008 | Office Equipment & Supplies
Fax forwarding
Function 7 set
54 set
1 for invalid set
stop
Sep 02, 2008 | Office Equipment & Supplies
Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax Logo
32 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
