Question about Uniden TRU8885-2 Cordless Phone
De-register/register How do you de-register a phone when all you get is "out of range"? Any and all help would be appreciated.
  • Susan Sigrest Jun 29, 2006
    Thanks so much Silly Girl - just for caring! I stayed on hold with Uniden for almost 45 minutes but got an answer finally!! If anyone ever asks this again, you hold down the "end" key and the "#" key at the same time for about 6 seconds, and it will de-register, then put on base to register. It works!!
    Thanks again!
  • elenabesi Aug 15, 2008
    Buenas Noches. yo tengo un tru8885-2 y se fue la luz o sea la energia electrica y en el telefono base dice Bienvenido! por favor espere.... y no puedo hacer nada con el ademas no tiene tono ninguna extencion y tengo tono de linea que puedo hacer ? gracias elena
To De-register handset while original base present:
-Use De-register menu
To De-register handset without original base present:
-Press and hold "End" button, and while holding that, press and hold # as well.
OR
-Remove battery
-While holding * and # replace battery, and keep holding
-You should hear one beep (let go now)
-Press right menu soft button (at top)
-Should hear one beep and Clear EEPROM/RAM on screen
-Remove and replace battery once again (no need to hold any buttons now)
(USING ANY OF THE TWO METHODS ABOVE MEANT FOR NON-BASE PRESENT, WHILE BASE IS PRESENT WILL TAKE UP HANDSET SPACE ON BASE, eg. HS1 will become HS2, while base reserves HS1 name... a base reset will be required to deal with this).
Resetting the base itself (if you have any handsets deregister them normally before this)
-Unplug power
-Hold 'Delete Messages' key while plugging power back until beep (88 or 0 messages may show)
-Press PLAY once
(To check that all went well, check to see if anything shows under ROOM MONITOR, nothing should be there)
Posted on Nov 25, 2009
  • technev Apr 28, 2011
    Legendary, if only the manual would explain how to do this.
    Doesn't mention how to reset base or tell you about de-registering handset will retain #ID in base.
Yes! To deregister units that are "out of range" or "unavailable" you hold the END and # button down for a few seconds and the phone will derigister. Place it back on the base to reregister. IMPORTANT! Push the END button first and hold BEFORE you push the # button.
Posted on Apr 03, 2008
To clear handset id, reset all handset id, clear handset register from base unit for TRU8885-2 TRU8885-HS, follow the steps below:
1) Disconnect the AC adapter from the main base.
2) While pressing down flash/find hs, reconnect the AC adapter.
3) On the handset, press and hold # until you hear a beep.
Posted on Oct 31, 2007
  • uniden8885 Oct 31, 2007
    If you are not familiar with TRU8885x unites, do not use the "End" key + # key to de-register handet, unless you original base unit broke, and you are register with a new base unit. Otherwise, the base unit will think the handset still exist, and will reserve the handset ID for the "de-register" handet.
    Note: I played around with my handset with "End" key + #; then re-register with the same base unit. This cause the same handset to be taken up all 7 "handset IDs" from the base unit!!! Which at the end, I can't register the same handset no more.
    To properly de-register, please use the De-register function on the handset.
Well the top selection did not work for me and Uniden is not answering due to unusual circumstances, I initially had the TRU8885-2 that I bought a year ago and I loved then. Now we have a big house and its like the ebay user failed to deregistering before sending them. No visible damage. Does anyone know of any other magic combination to reset the security clud?? Thx Wojo
Posted on Aug 31, 2007
  • tonywojo Aug 31, 2007
    please try this
    take out the battery
    put the battery back in while holding * and #
    you should hear a beep
    then press the top right or left button
    push talk
    put the handset on the base to register
Guess what? There is a "De-Register Handset" option in the handset menu. (I discovered it AFTER using the method above, which DID work for me.)
Posted on Feb 05, 2009
Hello RE; OUT OF RANGE/NO DIAL TONE I have had my telephone for 1 week now - I thought it might correct itself. I'm happy if its out of range/no dial tone and I need to de-register it once in a while, but 8-10 times a day. I dont think this is right. What is the problem? Was I sold a telephone with faults? - or, how do I fix my problem. Any help would be appreciated. My email address is tlewis@iinet.net.au Treena Lewis
Posted on May 18, 2007
Yep the End and # key does the trick
Posted on Apr 05, 2007
  • 513 Answers
Probably nobody here knows at the moment dear... I can give you a very lame advice, not because I think there's a good chance of it working, just so you're not left in the cold ;] Back when I had 2 identical phones with 2 different bases, we used to get mixed up once in a while and switched between the bases. I think I recall that it screwed the phones untill they were left to charge on their respective bases. This tells me that there is some sort of communication designed between the phone and the base when they are touching. Maybe what you could do is remove the batteries from the old phone for a day or two, let it reset, then place it on the base for the night. Like I said, this is a very long long shot, but I hope it works, or that eventualy someone who has seen your problem before will answer. Good luck!
Posted on Jun 26, 2006
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
De-register vtech ds6101 handset
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Jul 13, 2012 | Vtech Cordless 6041 Phone
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
OUT OF RANGE MESSAGE ON PHONE
De register and re-register the handset with the base.
Apr 15, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Uniden Tru8885-2
The older Tru8885 phones will not work with the new base unit. My recommendation would be to ebay those and then buy new ones or find replacements for your new base on ebay also.
Jun 19, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TRU8885-2 Cordless Phone Logo
1,734 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
