Question about Hansol 900 P (White) 19" CRT Monitor
My dead 900P
My monitor will not switch on, I have checked the plug fuse and wall power socket. Is there an internal fuse that may need replacing??? also the best way to take casing off to check for fuse.....
0 characters
1 Points
Crt Monitor Macer Model C708 as soon as i connect the power cable there is no power, no display
Have you checked that power is reaching your PC? First, check your power socket by plugging something else in. Next, you need to check the monitor's power line.If it has a fuse in its plug, check that by substitution if you don't have a test meter.It is very unusual for the power lead itself to get a fault because monitor power leads are heavy and of good quality.
It is possible that an internal fuse has blown, but if it has, there must be a cause. I would not advise you to even check that due to very high internal voltages even when power is off. Unforunately, CRT monitors are worth so ilttle these days that they are not worth repairing. Your best bet is to find a used monitor locally, which should not cost you much because they can hardly be given away these days.Look in your local papers.
Apr 06, 2010 | Relisys Intro TE770 17" CRT Monitor
Hey , i have Mag 900P monitor and i cant see nothing... the monitoe looks dead... but ther is a green light - power... should i buy a new monitor?
Hello there !
There could be a problem with the picture tube it could be dead( shorting) or the tube Transformer s damaged another course of this could be at the Horizontal section ie a Transistor or a Diode could be shorted .
Pls tell ur Technician to check all this .
Lastly Buy a new Monitor .
Good luck
Dec 05, 2009 | Mag Innovision InnoVision XJ 717 Monitor
MA203DT monitor dead again
I think it's trying to tell you something!
Time for a funeral. Best get a new monitor.
Oct 03, 2009 | iiyama MA203DT 22" CRT Monitor
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel
Aug 12, 2009 | Proview PL916S2 Monitor
Philips CRT Monitor 107 E66 SMPS dead Pls any one
The monitor might be 'dead' because the flyback transformer (specially primary section of it) is not working. You can try replacing it if it doesn't cost you too much.
Jul 22, 2009 | Computer Monitors
Viewsonic vx910 dead
Not that I know of. I'd say it's dead.
Feb 27, 2009 | Computer Monitors
Will not power up,
IEC Mainspower socket pins bent slightly to make sure contact was made with the plug.
Sep 25, 2008 | Samsung SyncMaster 213T 21.3" LCD Monitor
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
My monitor has no power on
First thing to check is the power supply cord that plugs into the monitor. Sometimes the internal transformers fail. Let me know if you have power to that. The way to check it is to plug the cord into the wall socket and use a multimeter tester set to DC Volts and see if you get voltage to it. Let me know if you get voltage there
Dec 05, 2007 | Dell E173FP 17" LCD Monitor
Hansol 900 P (White) 19" CRT Monitor Logo
Top Hansol Computer Monitors Experts
Matthew Spark
Matthew Spark
 Mike M
Mike M
Are you a Hansol Computer Monitor Expert? Answer questions, earn points and help others
