My Samsung CLP 600 Printer is giving an error message that the transfer belt is not installed. I tried a new transfer belt, but still get the error. Tried seating the door snuggly, taking the tranfer belt out and reinstall - nothing worked.
  • 5 more comments
  • dpatter Oct 19, 2008
    I have already checked that the latch on the door that opens to install the belt and get to the toners is fully down. I double checked by lifting the latch a little, lifting it did stop the printer from cycling, but re-setting it did not turn the no belt installed error off.
    transfer belt is correctly installed, double checked.
    I think a printer driver problem is a remote possibility. Looking for a solution related to the belt and how the sensor works/how to test or bypass it.
  • dpatter Oct 20, 2008
    The suggestion was to find the side with the three wires on the bottom of the belt transfer unit. The unit does not have exposed wires. There is a sensor on the bottom of one side, and there is some sort of electrical connection one half way up the right side of the transfer unit.
    The idea of resetting the printer from the menu was a good thought - but I cannot get to the menu - the install belt message error message does not let me get to any other menu. Is there a way to get to the menu, getting past the error message.
  • dpatter Oct 21, 2008
    The comment was - did I change toner cartridges lately. I did, but I don't have the old cartridge to put back in. Why would a toner cartridge change cause a problem with the transfer belt!!! I did put an old black cartridge in the slot for yellow - the most recent cartridge I changed - and that did not change the anything.
    As suggested - I did seat the door and lever firmly - no change there
    Read my previous comments - looking for new possible solutions to try!
  • 10,594 Answers
I'm sure that sensor is defective and such type of sensors are Infra red. You can test sensor's Infra Red LED by any digital camera or mobile phone camera but Photo Sensor test (other part of sensor unit) requires digital meter to check its hi-low status.
Good Luck.
Posted on Oct 21, 2008
    Genius:
  • 1,226 Answers
HELLO,
Disconnect the printer from the computer and then uninstall the driver. after uninstalling the driver restart your computer and then reinstall again the printer. if this not work try to verify also the connection components of the printer.
melnavz
Posted on Oct 20, 2008
    Brigadier General:
  • 6,966 Answers
Your post is about an error message "INSTALL TRANSFER BELT". Was there a recent change of toner (cartridge)? If, yes, is it an original? If not, pls try temporarily installing the old/original.
Alternately, try pushing the handle (on the side with the cartridge) really hard with a solid snapping action and sound. Sometimes the switch/sensor fails when done slowly/gently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Scholar:
  • 62 Answers
I know that this might not have any impact on a "not installed" message, but it couldn't hurt to reset the transfer counter if you haven't done that yet. This is the counter that you reset to clear the "replace transfer belt" message.
Menu - Maintainance - Check Others - Transfer Belt - Reset - Reset Now Hope this helps, Chad
Posted on Oct 19, 2008
  • 4,889 Answers
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. The side plate is about 3 inches long and has the two screws fixing it on. The sensor has a single screw fixing it, but in fact just looks like a black cover plate. Lever it out easilly at the screw end, not the other end which is impossible.
  • eagle338
    eagle338 Oct 20, 2008
    Ok... Does the sensor look like some kind of optical reflective sensor?
    Genius:
  • 1,550 Answers
Working of sensor .
The paper is picked up from the tray and advanced to the print zone.An LED shines onto the surface of the paper.The reflection of the light is captured and recognized. This reflection gives the printer information about the paper coating characteristics for the particular paper.This information is compared to a reference table of paper types that the printer has stored internally.Then, based on the information, the printer determines color mapping, half-toning, and number of print passes to produce the best output for the paper being used.The sensing process may add up to five seconds to the print process.
    President:
  • 1,952 Answers
.Maybe the transfer belt is misplaced check if it's correctly place...
http://www.retrevo.com/s/Samsung+CLP-600?rt=pd
With this link you'll have the user guide manuel, check how to replace the transfer belt....on page 38.
  • mohammed marika thambi
    mohammed marika thambi Oct 20, 2008
    If you have any setup issues or receive error messages, please try updating firmware before contacting tech support.
    y cant u get it from ur manual...
  • 13,433 Answers
It is because the sensor is not aware that the side is shut. You have to push the handle in (the one used to open the side with the cartridges) as far as it will go to alert the sensor that the side has been shut and the transfer belt is installed and in place.
    Scholar:
  • 84 Answers
Well i think your printer hardware driver having problem install new one
  • 3 more comments
  • rush2aaman
    rush2aaman Oct 19, 2008
    This Samsung Image Transfer Belt is specifically designed to ensure longer yield, enough for general business. It features print quality with crisp, vibrant output from the first page to the last page. The easy-to-install image transfer belt provides cost-effective, reliable operation and sharp, professional results every time. This belt is compatible with Samsung CLP-600, CLP-600N, CLP-650, and CLP-650N printers. It yields approximately 35,000 pages at 5% coverage
  • rush2aaman
    try the driver from the link:
    http://update-your-drivers.com/download....
  • rush2aaman
    your operating system is windows xp aur vista
  • rush2aaman
    if your operating system is windows xp then download driver from
    http://downloadcenter.samsung.com/conten...
    if your operating system is windows vista then download driver from
    try them
  • rush2aaman
    ok you check the drivers or not
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
Sep 09, 2013 | Samsung Image Transfer Belt...
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Internal error on samsung clp 300
what you need to do is get a new transfer belt, if you email the company they should give you a new one.
Feb 02, 2009 | Samsung CLP 300 Laser Printer
"Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Dec 30, 2008 | Samsung CLP-500 Laser Printer
2 Errors
Transbelt is a part replacement-plain and simple. Samsung sucks for this, they give you no warning and just shut down the printer. www.samsungparts.com
Oct 13, 2008 | Samsung CLP-500N Laser Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Samsung printer error
Time to buy a new transfer belt. samsungparts.com
Apr 29, 2008 | Samsung CLP-500N Laser Printer
Samsung 600N transfer belt
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
Apr 20, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Electro Med Services...
