Question about Sony Cyber-Shot DSC-U20 Digital Camera
Black LCD Image w/ flickering static lines
The camera turns on and I'm able to see the menu settings alright. The only problem is that the image I see in the LCD is a black screen that has flickering static lines that come and go every few seconds. I believe that the static lines are the "windows" of light the lens is able to catch, as I've noticed that the colours of them change slightly when different coloured items are placed in front of the lens.
  • SONY DSC Apr 06, 2008
    i have excatly the same problem. But sony charge £150 to fix it.. is there cheaper way ?
Http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCU20
Go here and you can get a request for free repair. It will cost $15.00 for shipping.
Offer ends March 31, 2009
Posted on Oct 29, 2008
    President:
  • 3,130 Answers
Your camera is on a list of a recall because of bad image sensors(ccd) Contact sony repir in your owners manual and see where they want you to send it , as even if its out of warrantee it will be repaired. Try this # or like I said a contact # in your owners manual 800-488-7669 Good Luck
Posted on Jun 21, 2006
I have a Nikon D3000 digital camera. When I turn it on the info menu is displayed on the monitor and I cannot see the image that I am shooting. When I turn the info menu off it turns black and says...
That is the factory setting. If had seen the image on the LCD before taking the picture, then there was something seriously wrong with the camera. The D3000 works as SLRs have worked for over half a century, providing you with a viewfinder to compose your photos.
Aug 15, 2011 | Nikon D3000 Digital Camera
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
No preview image. Black screen LCD
The problem is not with the LCD or the camera - You have got it set to ecomony / power save mode. Fixable through camera settings.
May 10, 2009 | Panasonic Lumix DMC-LX2 Digital Camera
No image in the LCD, its black
Hey my27my,
What is most likely the cause of this is the LCD is turned off in the shooting mode. To fix this you need to turn it back on in the record menu. Directions on how to do this are on page 59 of your camera manual. I have included a link to a download of your camera manual in case you need it. I hope this helps!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=9449#DownloadDetailAct
Sincerely,
Allan
Go Ahead. Use Us.
Jun 26, 2008 | Canon PowerShot A80 Digital Camera
Image on LCD jumps
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Sony Cyber-Shot DSC-U20 Digital Camera Logo
238 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
