Question about Bose Lifestyle 12 System
Humming sound I have a Bose Lifestyle 12 system which I bought 6 years ago. Of late, whenever I turn on the receiver, I get a continous humming sound coming from the sub-woofer. The same thing happens when I have it connected to my tv. Surprisingly, when I played a music CD, it the system performed ok as it should be. Would you have any idea what could be wrong ? If I need to take it the the service centre, I am not sure if I have to bring the whole system - or perhaps just the sub-woofer. Thank you.
  • Anonymous May 22, 2009
    Hi, we have the same problem. When the Bose woofer is left on but the amp if off a vibrating humming and every 5 mins or so a popping sound.I always need to turn the woofer off.
    New Friend:
    Problem Solver:
  • 15 Answers
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
Posted on May 15, 2017
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: bose lifestyle no sound
I' have pulled out the plug for more than 1 min, and afterwards it worked again. Full sound again
Posted on Feb 02, 2008
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
Posted on Mar 01, 2009
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
Mar 04, 2011 | Bose Lifestyle 12 System
My Bose Lifestyle 12 - No Sound
What sound are you putting into the system? Have you checked that the audio you're putting into the system works into some other device? Have you checked that you have the correct input device selected?
If you have checked that the audio going into the system is working properly and you have the correct input device selected then yes, audio in but nothing out = something is broken inside.
Nov 01, 2017 | Bose Lifestyle 12 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
No Sound from the speakers
sounds like the amp went , you will need to call bose
Dec 09, 2008 | Bose Lifestyle 12 System
Lifestyle 12 receiver vs lifestyle 12 II
yes will work just fine, a slight difference in the output gain from the control baord, but in almost all other cases you wont know the difference. just make sure especially if you intend to use the old cd unit with the new bassbox that if you connect the digital source to to (say dvd player) that you initially use bose remote to turn on bass baox and set volume.
Jan 17, 2008 | Bose Lifestyle 12 System
Bose lifestyle 12
There is a solution to send your Bose in for the repair at They turn the unit around fast and are lots cheaper than what Bose quoted me.
Nov 28, 2007 | Onkyo TX-SR500 Receiver
Bose Lifestyle 12 System Logo
73 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
