SOURCE: please help
your problem is your linear intergrated amplifier chip has blown, or has dry joints. causing you system to go in to protect mode which stops more damage being caused and fire not occurring. if you have no technical back ground in electronics, then i wouldnt attempt repair yourself. if you have take cover off and on the long metal heat sink there is a black like box with between ten and thirty legs going in to circiut board thats your problem, theres a code on the front of it with 2 or 3 letters then a number, thats your part number they range in price from between £7.00 to 50.00 pounds.. hope this helps
SOURCE: Jvc stereo receiver CA-HXD7
RP206 = 100 ohm 5% 1watt ( also check PQ105 : 2SA1273 PNP transistor )
SOURCE: PROTECT MESSAGE
Most likely he has a couple of the connectors crossed. It is going in protect mode to keep it from damaging the internal electronics. Open it back up and double check all connections. then let me know.
SOURCE: connecting jvc shelf stereo model # ca-hxd7 to a television and karaoke machine
I'm sorry, but you won't be able to that.
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
