Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HDTV 52 inch television
Picture comes up with all colors of the rainbow +3D picture.(example) 2 noses,two eyes all framed in colors of the rainbow. This appeared after my cable box went off, screen blackouts, rebooted box. This problem ever since. Was this caused by a faulty cable box ? Purchased in 2006.
  • burnsedv Dec 22, 2008
    tv comes on then after a few seconds it turns it self off whats happening
    Scholar:
  • 86 Answers
If a DVD and the onscreen menu looks sharp and problem free, I would say it's the cable box. Since you only reset it, I doubt it has anything to do with the cables unless you removed them and didn't insert them properly or tight enough. Try a power drain on the cable box:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. This will also reset the cable box again, but draining the power can do wonders.
Posted on Oct 20, 2008
I have an 52 inch hdtv model number hd52w59 and my tv was workin fine and then it started to make this popping noise in the back and now sometimes my menu screen pops up the volume changes and it changes...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture with rainbow colors
The convergence circuit is not working. There are bad solder connections on the flyback transformer and a small fuse has opened up. This is not easily done yourself unless you have a technical background but an RCA technician can fix this no problem.
Mar 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture problem with rca 52 inch hdtv colors split not in focus
Hello, If your picture looks like a "3D image" you need convergence IC's . Red and or blue picture is not converging on top of the green picture. They are mounted on large, finned heat sinks. The # on the IC's starts with "STK-" followed by numbers.They are available through tritronicsinc.com for $15 to $35 each. Good luck.
barneyluc
Oct 10, 2008 | Televison & Video
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV 52 Inch
If its only one color its the Convergence amp board that needs replacement. If its more than one color you cant control you need the Convergence power supply board. If you need parts for your model let me know and I will post a link.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
