Question about GE (PSS26MSRSS) Side by Side Refrigerator
How do i locate the defrost timer on my refrigerator?
Trying to figure out why my freezer keeps frosting up and making the fridge part warm. Everything i have found on line points to the defrost timer.
I'm having the same problem.I checked out my fridge and found the defrost heater bad. I replaced it and also replaced the defrost thermostat. It fixed it for about 4 days and then the problem reocurred. I strongly believe that one of the relays that are built into the circuit board are going bad or getting stuck. I just hate to replace the board and have the same problem again. But, i have already replaced all other components of the defrost system, so the circuit board can only be the problem. I'm going to give it a shot.
Posted on Oct 20, 2008
GE GTS22KHP refrigerator - fridge is warm, freezer seems cold and is making ice. When the fridge was getting warm, we checked the freezer and some of the food in the door of the freezer was starting to...
With 'no-frost' fridgerators, they enter a 'defrost' cycle that is supposed to elimnate any frost. There are a few suspect parts, but it should be 1 of 2 parts. The timer that controls when it enters the 'defrost' cycle is occuring too often, or more likely, there is a thermostat that overrides the timer once the temp on the cooling coils (not freezer) reaches, say 55 degrees and commands the freezer to resume cooling.... I bought a themostat off amazon for $26 and put it in and no longer have my ice tray frozen solid after prolonged defrosting. Google 'no-frost' fridge how it works...
Oct 24, 2011 | GE GTS22KHP Top Freezer Refrigerator
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is warm. Freezer did not frost up. Will not keep food cold. . . stays warm.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 02, 2011 | Refrigerators
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
heatman101
Dec 22, 2010 | Heating & Cooling
Hoover a class, fridge freezer, fridge keeps icing up and is supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 21, 2010 | Hoover HCA390FFK Bottom Freezer...
Temp is too warm inside
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 26, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Fridge is warm and freezer is cooler than normal
Possible bad defrost timer. Locate timer underneath the fridge and manually turn the knob. Element should come on and start defrosting. If defrosting starts then the timer is bad. Check also the element and thermostat.
Jul 05, 2009 | GE Profile 21.6 cu. ft. Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
