TV is not working
I bought a Goodmans LD1945WD tv about 3 weeks ago and now it won't work.It is stuck on one channel (BBC1) and the volume would only go down so it is now on zero.The remote does not work,i have tried new batteries.I can take it off stand-by using the on-off button on top of tv, and the channel and volume on top of tv does not work,neither does the source button.I can bring up the menu screen but that is it.Please can you help.
  • cbrad-65 Oct 19, 2008
    I am not able to scroll down on the menu screen,It comes up on the screen and that is all it does
    Scholar:
  • 188 Answers
If it's 3 weeks old bring it back if you can. There should be at least a 30 day warranty. When the channel and volume buttons on the TV don't work it sounds like something failed.
Posted on Oct 19, 2008
  • 84 Answers
Try auto program in the menu for channels and try pulling the buttons out one may be stuck
I tuned my goodmans LD1945WD TV for the freeview channels. After using them for a couple of weeks my DTV channel only shows a black screen. I can't change channels, rescan or receive any freeview...
Check out a reset to this set first. If it do not help you, check and replace the main system control memory IC. Contact any service technician. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 06, 2014 | Televison & Video
Why won't my Goodmans digtial box remote change channels or volume on the TV?
Think about it. The digibox remote should only change its own channels, not the TV ones. Otherwise the TV would never be on the correct channel to see the digibox signal.
As for the volume, unless the Goodmans remote is programmable to emulate the TV volume, then it will just change its own volume. The result is the same. The TV gets louder or quieter.
Sep 03, 2014 | Televison & Video
Why is the Goodmans digital box remote not changing the channels or volume on My Daewoo TV?
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
My Vizio M261VP was purchased three weeks ago. A week ago, the audio on channels other than the digital HD channels are very low. For example, an analog channel or Netflix via the VIA the volume needs to...
I would return the Set ASAP! TV has a factory defect,take it back and get you another TV,
and If it happens to do the Same thing Then Company might have more then several TVs that must be returned to Factory.
I had a Friend of mine who bought a new Tv got it home it had a problem she took back 3 TVs and they all where doing the same thing.She just got her money back and went to another store.
But they did Offer Her Another Set from company.
Feb 27, 2011 | Vizio M261VP 26" LCD TV
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
LAST WEEK WHEN I TURNED ON THE TV ALL THERE WAS ON TV WAS THE SPORT'S CHANNEL AND ALL OTHER CHANNELS ARE NOT WORKING.WE JUST BOUGHT THE NEW LARGE SCREEN TV 3 WEEKS AGO
yOu cant blame tHe tv.. n.n you have to check the cable connections in your place.. n.n nC tv you got there. . hope this helps
Jun 06, 2009 | Sony BRAVIA KDL-46V3000 Television
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Volume and channel control on TV not working
The control board is defective. Is in warranty so call Sharp to have it fixed.
Dec 29, 2007 | Sharp LC 37D62U 37 in. LCD HDTV
Televison & Video Logo
264 people viewed this question
Top Televison & Video Experts
