Question about RCA L26W11 26 in. HD-Ready LCD Television
RCA L26W11 quietly died.
Just watching a channel and the screen goes black. Repairman says is a digital board (Video card?) but if fixed the 350 $ plus 85 for house call makes it unreasonable when a present RCA 32" would be only few dollars more. In addition he says the card is available only a month later.
The card alone is 170$. So stiff?
Looking for the real cost of the card and where I can buy one.
Bruno
  • 2,336 Answers
Hello Bruno,
These LCD's were manufactured in or around 2006 or early 2007. Service parts are hard to find or not available.
I would suggest to invest in a new TV instead of fixing this one. If you intend to DIY, check the link to see if they might be able to help you find parts or know where to find them.
Let me know if you would need further assistance.
Posted on Aug 11, 2017
Tech4lfe
  • 42 Answers
SOURCE: channels won't stay put
Sounds like you may have a stuck button or bad switch on the keyboard. In rare cases you may have something interfering with the IR which you can test by blocking the sensor on the TV.
Posted on Jul 06, 2008
circuitworld
  • 335 Answers
SOURCE: rca 32 screen turns on but stays black
Theres no start-up signal being encoded, this means the interface board has an offset capacitive value. You need to test and measure the capacitors and npn/pnp transistors, along finding some open diodes too on the main board (interface). You have to test the capacitors under their operating voltage also to see at which point their breaking down. The problem is a 'load' condition on the main board. You can repair the board if your savy and you have test equipment or you can just replace the board. If you want to replace it e-mail me and I'll help you out....
Posted on Nov 25, 2009
welcomejee
  • 10594 Answers
SOURCE: When I turn my L37WD12YX1 tv on. It takes a few
Question details gives idea that standby power supply board seems cause of problem, tv has two power supplies, one is standby power board as shown in below image and other is main power supply board that is bigger in size.
I guess you sent out main power supply board for repair that did not make any difference on tv problem.
Check out following image of standby power supply board and replace marked capacitors and resistor carefully (5 parts) if you do it yourself or ask local repairman to fix it.
Standby supply output voltage seems lower than requirement of tv and causing start-up problem. These voltage goes to system control chip that controls other functions of tv and standby volts must be stable and accurate to turn On tv properly.
I hope these info will solve your tv issue.
Thanks.
Posted on Oct 04, 2010
eagle338
  • 4889 Answers
SOURCE: I have the above listed TV, and have asked for
Do you mean you cannot see anythiing on the screen? Does the backlight come on(You will have a dull glow on the screeen if it does). Please answer these questions so that I can help you with your problem.
Sai.
Posted on Oct 16, 2010
maatmartin7
  • 1229 Answers
SOURCE: 32" RCA Entertainment Series, Guide
Probably not. RCA parts for this model are very difficult to find. Even you could find a kit, it will not have enough to repair. A do it yourselfer or TV tech will have a difficult time repairing this. Please shop for a new TV. Thanks for asking and show a few hands of support!
Posted on Mar 21, 2011
Both when playing games via RCA or HDMI, and when watching cable, the tv screen randomly changes to verticle multicolored lines. If I unplug it and plug it back in, it may go all day with it happening...
The tvs shops will cost u like around $300-350 for the board part that call the T-CON board and labors.The board that call the T-CON board it is shorting out and dying to causes this.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement by ur self.The T-CON board probally will cost u like 80-90 dollars plus shipping.
Jul 15, 2011 | LG 42LC2D 42 in. LCD HDTV
RCA L26WD21 No picture/white screen but still have sound
It sounds like the LCD controller board went out, look inside to see if the cable may have come off the LCD controller board. You can look and see what it looks like here: http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L26WD21+
Please post back what you find.
Dec 25, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
RCA L26W11 SERVICE MANUAL
try retrevo.com or www.epanorama.net or www.servicemanuals.net
Sep 16, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
Channels won't stay put
Jul 03, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
TV Screen not functioning correct
Sounds more like a malfunction. Most likely the lcd panel or digital board. If lucky possible a bad solder connection but unlikely.
Jun 05, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
New tv won't set up channels
We are returning the tv to RCA and getting our money back.
Apr 18, 2008 | RCA 24V510T 24" TV
Rca Goes Green
replace video ic on Green CRT broad,also look for leaky capacitor on same broad replace it also, If this does not fix it then you have a bad green tube!
Nov 29, 2007 | RCA HD52W59 HDTV Projection Television
Watching tv and screen goes black w/no more sound!
you can check only for the fuse if it is busted or not
locate the fuse. check if it open using a tester.......
if you have no experience yet on electronic servicing then you can fix it.
Nov 13, 2007 | RCA TruFlat 27F520T 27" TV
Just got digital hd
If you press the zoom- button on your remote it will give you options for the screen size. The "stretch" option might help.
Oct 17, 2007 | RCA L26W11 26 in. HD-Ready LCD Television
RCA L26W11 26 in. HD-Ready LCD Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
