Casio Exilim EX-Z40 Digital Camera
Problem for Casio Exilim EX-Z40 Digital Camera
Flash not working
By pop56 on Jun 20, 2006
the flash does not work .i have reset the camera and checked flash is set up right and cannot get the flash to work . it looks like the flash bulb may have broken can anyone recomend some one to repair this please.
Same Problem
Jan 20, 2009
-   I have a sony CYber-Shot DSC-P93A the flash doesn't work how can i fix this or where can i take it to be repaired?-   madtv1104
Dec 28, 2008
-   my flash did not work, but i can still use my camera to shoot for photo, the only problem is i can't use my camera in night or in dark place coz' it didn't work. is there any place that i can bring my camera to fix the flash bulb. my unit is sony cybershot-   vallotte
Dec 15, 2008
-   I have a Sony Cyber Shot DSC-T33 its Flash is not working kindly provide me the solution, how can i repair? -   Guest
Dec 07, 2008
-   flash does not work properly.
and a blinking yellow light appears
and E:91:01
Blinks CONSTANTLY.
my camera is pretty knew. how can I fix this???-   Guest
Sep 01, 2008
-   Kodak EasyShare CD33 Digital Camera is giving a problem of a flash whicg does not work at all .
I have followed all guides given in manual but still there is action taken place.
What might be the problem and what would be the solution to the problem.-   Phoka
Solution #1
posted on Jun 21, 2006
Somewhat Helpful)
scrajmer
Rank: Wiz
Rating: 81%, 500 votes
the flash bulb or tube does not go off suddenly. it gets weak after yers of usege or breaks only if the camera is dropped. most of the flash related problems occour for non charging of the flash. pls contact local repairer for this problem
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have had this problem.  HP support was useless.  My problem occured just before the warrantee expired, so I called HP and they suggested that the battery wasn't supplying a sufficient charge.  They gave me a free battery and it worked for a month, then the flash stopped working again.  I called them back, but they now said I was out of warrantee and pointed me to a page of refurbished cameras that I could purchase.  Thanks, but no thanks.  They label says made in China, so I suspect substandard Capacitors that power the flash have failed.  I still use the camera as a backup when I don't need to use a flash the flash.  I've opened up the camera to locate the capacitor, but found too many connectors and didn't have the time go completely disassemble the whole thing.  I've put it back and it still works.
I will no longer buy HP products.  Their customer service is lacking and they have lost me as a customer.
Popular Solutions for Casio Exilim EX-Z40 Digital
Questions and Unsolved Problems for Casio Exilim EX-Z40 Digital
Do you recommend Casio Exilim EX-Z40 Digital Camera?
Answer
Answer
I dropped my Casio Exilim Z-40, and now it doesn't take photos any more. But I can view the ones... (More)
Answer
I have a Sony Cybershot 4.1 digital compact camera. I took tousand of pictures with it. For some... (More)
Answer
As I lightly touch the set and arrow keys the menu pops up it is really annoying. It fickers on an... (More)
Answer
When I turn on the camera, the language setup along with the date and time set-up appears. I have to... (More)
Answer
Exilim Z40 - When you press the shutter button, green and red light come on in upper right corner,... (More)
20 Other Users Have The Same Problem - Continued
Comment by dawnymac, posted on Aug 29, 2008
Hi, My Pansonic DMC LS70 is only a few months old and the flash appears to have blown, I heard it "pop" while taking a photo and it no longer works! I haven't dropped it! Is this repairable? Thanks!
Comment by laxlyss, posted on Aug 04, 2008
I have an exilim EX-Z57... I've had it for about two years...I dropped it a few times.. a few dents here and there. I tart up the camera fully charged and it takes pictures...only without flash. Since pictures look better with flash on my camera, I'm naturally pissed. I am just wondering would the drops have done it? If anyone knows explain the science behind it ( circuit board for ex.)  I'd like to know any ways t fix it myself. And if not, who I should go to for help for something cheap and efficient. How much do you think it would cost?
Comment by u_libra87, posted on Jul 13, 2008
The flash is not working.When I press the up control then also its not getting activated..Also a continous number like E:90.1 is flashing continously
Comment by bmcnally, posted on Jul 09, 2008
The flash recharge light is blinking and wont take a picture unless I cancel the flash, how do I fix this? It just happened after many years of owning this camera trouble free.
Comment by halbergenox, posted on Jul 08, 2008
I can not make the flash work
Comment by gtsherry, posted on Mar 27, 2008
Not only has my flash stopped working, but I also have the problem with my battery door not closing properly. I have tried to reset the flash, but it does nothing. The battery door, well.... I just try to hold it shut with my thumb while I am taking a picture. I have had the camera for awhile and I loved it up to this point. Please help!
Comment by Guest, posted on Mar 19, 2008
problem same as other's
Comment by KW2000, posted on Dec 13, 2007
The flash stopped working, no known cause. Tried to reset but did not make a difference. Is it worth the price to get it fixed or am I better off just getting a new camera?
Comment by 700 ocean, posted on Dec 06, 2007
I've had this camera just over a year. Flash has worked without any problems and then suddenly it stopped. I have charged the battery pacts
and attempted to reset------no luck.
The camera has not been dropped or damaged at all. Unable to get any assistance at Kodak website.
Comment by Guest, posted on Dec 06, 2007
i have a Pentax Optio E10 Digital Camera and my flash is not working how do i solve that?
Comment by Guest, posted on Nov 26, 2007
Have the same problem with flash stop working. Bought a 2nd sd600 and the flash has stopped working on this camera. Neither camera has been dropped or abused.
Comment by alinerajao, posted on Nov 24, 2007
My flash doesnt work too from the day I bought the camera. The orange light in the front turns on but the picture is not taken. So, in dark places I never can take pictures. The camera cant take pictures when the flash is set to on or automatic.
Do you think that can be a configuration problem??
Comment by marleesxox, posted on Nov 16, 2007
My camera will not turn on.  The battery is charged but when I try to turn it on the screen is black and the lens go out half way.  Is there any way I can reset my camera?
Comment by Guest, posted on Nov 04, 2007
i have the same problem.. Mine has not worked right from the day i bought it
Comment by Guest, posted on Nov 01, 2007
I have the same problem. The camera has not been dropped, has not been in use for years, I've only had it 14 months and don't use the flash a great deal and when I do it's been the soft flash setting. Of course the obvious thing to do is get it repaired, I'm just saying that I've experienced the same problem. Could it be a fault with this particular model?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio Exilim EX-Z40 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
