Question about Samsung Digimax L730 Digital Camera
Samsung l730 camera
The camera as been up until now, it now wont let me do anything all it keeps saying is card locked... any ideas..thanx
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
Take out your memory card, check the left side that says lock with the arrow down the very side with small white button to unlock slide the up or push the button up to unlock your card.
hope it works.
Posted on Feb 08, 2010
Card locked samsung L730 digital camera
Move the slide switch on the side of the card.
Mar 30, 2010 | Samsung Digimax L730 Digital Camera
CARD LOCKED appears oo screen, camera wont work?
Does this camera take a memory card, separate from the built-in memory of the camera? If so, remove that memory card and look closely at all sides and edges, to make sure that there is not a read-only protection switch on it.
Many of these memory cards have tiny switches, sliders back and forth, that protect the memory from being erased.
If you slid that switch into the locked position without being aware that it is there, and without knowing that you did, then the error message makes sense.
Remove the memory card and look at it very carefully.
-a.
Dec 10, 2009 | Samsung Digimax L730 Digital Camera
My samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Jan 03, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 10, 2008 | Samsung Digimax L730 Digital Camera
Samsung L703 didital camera wont turn on
For me also same problem No power ON Green LED blinks
Oct 28, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
104 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
