Question about Brother IntelliFAX 4100 Laser Fax
I need a manuel to speed dial numbers - Brother IntelliFAX 4100 Laser Fax
    Genius:
  • 2,120 Answers
Go to www.brother.com for a download.
Posted on Oct 19, 2008
Speed dial option in Karbonn K451+ Gold champ
Hi Nilesh, the user's manual says, quote: "Speed dial: If you already set the speed dial numbers, then you can long press number key 2 to 9 to dial set numbers out under the standby mode.Long pressing number key 1 is to dial to voice mailbox if you already set the mailbox number." So it looks like you need to add the speed dial option in your chosen contacts details, first. Then follow the quote above. Good luck!
Dec 19, 2014 | Cell Phones
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
My nikon D3100. when i scroll the Command dial for increasing the Shutter speed the Shutter number indicator did not move.
turn the other wheel increase your ISO or your speed or turn the wheel the other way put your camera in M for Manuel
Nov 01, 2012 | Nikon D3100 Digital Camera
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Need manual for SBC Freedom Phone Model HAC FC2548
to programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
Dec 15, 2008 | Southwestern Bell (S60802)
Samsung SF 330 Spped Dial
Go to the Samsung website (Google Samsung). and then to their Customer Support Page. Then look for Downloads, or Technical Help, and look for the manual for your model. It will make it easier for you if you first write down the Model Number and serial number of your machine. With a bit of searching you should find what you need. Please don't forget to rate this answer.
Jun 03, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
