Question about Dell Latitude D600 Notebook
Thank you for trying to help me! Janetmull - Dell Latitude D600 Notebook
  • 849 Answers
No problem
Posted on Nov 04, 2008
Tip
Just have to say......THANK YOU! THANK YOU! THANK YOU! you helped us fix the...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 21, 2011 | Kenmore Elite 45986 Front Load Washer
Dear : to Zynga Customer Service, My account facebook is jaya_piter@yahoo.com, today on June 12, 2011, when i'am play poker texas on zynga, suddently my status said i'am not loggin yet, so i...
Dear : to Zynga Customer Service, My account facebook is jaya_piter@yahoo.com, today on June 12, 2011, when i'am play poker texas on zynga, suddently my status said i'am not loggin yet, so i quit from facebook and try to log-in again but failed, the warning said " i entered the old password " i never change my password before, please help me to find it my problem, i though someone use my account facebook and change my password, please ...please ..please help me, very much say thank you for your help, Thank you - Piter
Jun 11, 2011 | Zynga Texas HoldEm Poker
I charge the battery and try to start but does not work i test the battery and it is fine so i dont no what is the problem please help thank you
Does it try to turn on or anything when you try to start it? Does the lens move? Please provide as much detail as you can so I can help you. Thank you
Benjamin
Nov 04, 2010 | Rollei X 8 Sports Digital Camera
THANK YOU LEECOM72!!!
To resolve the problem , you would have to unistall client for netware protocol.
1.Click start>Click on RUN> Type ncpa.cpl and click on ok
2. Network connections window would open
3. Right click on Local area connection
4. Left click properties
5. Uncheck the box next to Client of netware
6. Click ok and restart your computer
Then try to select the Use welcome screen
Thanks
proton
May 29, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
NEED HELP
try the power button, make sure the battery switch is set to your type of batteries
Mar 13, 2009 | Uniden Radio Communications
Need help please
It sounds as though there is either a problem with the operating system, or the hardware is damaged.
You can first try to wipe the BlackBerry using the steps in the links below:
(Try this one first): http://blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
(Try this one if the first doesn't work): http://blackberryfaq.com/index.php/What_to_do_next_if_Jl_Cmder_will_not_connect_and_wipe
If that doesn't work then you may need to have the device serviced, or try another battery.
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Can't gain access to internet on Dell D600 used laptop
Let’s check the network controller on your laptop. . Go to "Device Manager" and look if any yellow or red alerts are being displayed next to “Network adapters”. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
If you have any other questions please contact me.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Latitude D600 Notebook
Printing photos
Try switching from 4x6 setting to 6x4 or portrait to landscape.
Mar 08, 2008 | Konica Minolta magicolor 2430 DL Laser...
Dell Latitude D600 Notebook Logo
22 people viewed this question
Alun Cox
