Question about HP Photosmart D5160 InkJet Printer
THE EXLAMATION MARK AT THE TOP OF THE PRINTER IS FLASHING AND THERE IS A LINE GOING AROUND THE SCREEN ON THE DISPLAY PANEL, THE PRINTER WILL NOT RESPOND TO ANYTHING, THANKS
  • 8 more comments
  • Anonymous Oct 22, 2008
    same problem
  • jobaxun Nov 03, 2008
    Had the exact same problem after loading a new HP cartridge. Spent an hour witht he HP helpdesk and no cure forthcoming.
    Printer truns itself back on after being turned off and red light continues to flash.
    Any clues, anyone?
  • Anonymous Nov 29, 2008
    I have this same problem, nothing seems to work. The printer is relativly new, and I just recently put in new ink cartridges. I'm ready to trash the printer and never buy another piece of this junk!
  • mordyt Jan 25, 2009
    i posted a solution ut if anyone comes up with a better one....
    i posted a solution but if anyone has a better one
  • angella12 Feb 08, 2009
    i refilled the cartridges and since i put in the exclamation sign been on. this is not the first time i refilled the cartridges. the first time i did this it did it for the day and when i got up in the morning it was fine. what could be the problem now. did i run out of luck this time
  • Anonymous Feb 24, 2009
    Same problem.
    The solution is to re-insert the new ink cartridges FIRMLY. I didn't press hard enough the first time.
    I also used my finger to clean the back of the cartridge, where the gold contact touches the printer. Problem solved. Thank you, I was going to trash this printer!
  • Anonymous Apr 16, 2009
    Re-installed the cartridge did it! Thanks.
  • Anonymous May 05, 2009
    same problem
  • dg66 May 11, 2009
    I have the exact same problem. I've tried everything. I'm ready to trash it unless some one has a solution please. It's only about a year old
Had exactly the same problem - it was the switched activated by closing the lid. The mechanism had becomed jammed, so the red light always came on. I removed the left-hand plastic cover of the printer (looking from the front) - first release the clips underneath, then gently release the rest of the clips (no unscrewing needed). You'll see two sliders at the side of the control panel - push them up - problem goes away. Hurrah :D
Posted on Jul 04, 2009
There is a flag switch located to the left hand side of the top cover that causes this issue
if you look at the left hand lip of the top cover, you should note that it does not meet flush with the top of the control panel, there is a cutout for the lever for the flag switch that appears to not move as smoothly as designed, my guess is a mismounted switched or a misaligned axle for the switch
you can actually access the switch lever itself when the top cover is open, just reach in and wiggle it until it depresses properly, you may have to do this (or at least check it) every time you open the top cover
Posted on Jun 21, 2009
    Problem Solver:
  • 5 Answers
Open the cover, disconnect an ink tank and reconnect it, close the cover firmly. works every time
if i helped you please rate me. i joined just because i spent hours trying to fix it and know how frustaring it is
Posted on Jan 25, 2009
  • HP Master
  • 4,338 Answers
Here is a HP solution page that should help each of you:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01041365&dlc=en&product=1155996
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 30, 2008
Not booting up when powered on. It starts like it's going to but screen goes blue then flashing hash mark at top left of screen.
PRESS ESCAPE EVERY ONE TO TWO SECONDS AFTER POWERED ON THIS SHOULD BRING YOU TO A SCREEN THAT GIVES YOU OPTIONS TO BOOT IN SAFE MODE OR GO TO A SETUP SCREEN
Apr 03, 2013 | Dell Inspiron Computers & Internet
I have a printer Lexmark W840. On the display there is a message "84 Replace PC unit" - what does mean?
The PC cartridge needs to be replaced. If you have just installed a new unit, please check if the PC cartridge is installed securely.
For further assistance please contact Lexmark Technical Support.
Feb 16, 2011 | Lexmark W840 Laser Printer
The red exclamation mark keeps flashing and on the left half of the printer's screen there is dashed lines that keep going around in a rectangle pattern. I turn the printer off and then the printer turns...
use the printer settings on pc to diagnose the problem through its menu possible paper jam or an ink that is done and requires replacement but do check if there is no paper jammed in the machine and that all the doors and covers are closed
Oct 18, 2010 | HP Photosmart D5160 InkJet Printer
What does the exlamation point icon mean on the
Go to the maintenance help screen and it should show what the problem is. Low ink can be one for it
Jun 16, 2010 | HP Photosmart C4150 All-In-One InkJet...
Icon 'sun' with an exlamation mark
Hi, I think you may mean the low brake fluid warning light.
Hope that helps Matt...
Nov 22, 2009 | 2001 Volkswagen Passat
My laptop screen has a thin blue line going down, why has this happened?
You have the beginning of a failing Display panel, and will eventually need to replace the display.. you can hold the top left and right sides of the display screen-slightly bend forward and back, you should see the blue line either go away or it will produce more lines...
This is due to a short on the circuit board panel on the backside of the display panel that controls the Pixels on the Screen.. The Pixels are controlled In a Line Grid Fashion...
Nov 16, 2009 | Dell Inspiron E1505 Notebook
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Red exlamation mark flashing
Usually this either means a paper jam or an ink cartridge is empty. If it is not paper then check your ink it probably needs a new cartridge. Hope this helps.
Dec 21, 2008 | HP Office Equipment & Supplies
FLASHING LIGHTS AND PRINTER NOT RESPONDING
seems to have sorted its self out now i just kept turning it on and off and trying to print off test pages and things, still not 100% but works of its own accord lol
Jun 06, 2008 | HP Photosmart D5160 InkJet Printer
84 Replace replace photoconductor
Reset Procedure(s)
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Dec 17, 2007 | Lexmark E340 Laser Printer
HP Photosmart D5160 InkJet Printer Logo
1,084 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
