Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Help w/ the flashing green light
I have a WD-52725 The green light constantly flashes. Ocassionally it will go red. I have uplugged the surge bar and pushed the system reset, also replaced the bulg. to elliminate the red light. However it works occasionally then goes back to a flashing red or green the nest time I turn it on?????
Please help
Steveweidenheft@sbcglobal.net
  • 3 more comments
  • Anonymous Nov 12, 2008
    Where are all these boards that the capacitors need to be replaced on?
  • boschrealtor Nov 20, 2008
    green light flashing, tv will not power on, tried unplugging for 24 hours, still flashing green light
  • bmeck2003 Dec 04, 2008
    I have a Mitsubishi WD-52725 and had to unplug it today. When I plugged it back in, the green light flashed and kept flashing. I could not turn the set on.
    I followed the instructions in the troubleshooting pages of the manual and pressed the reset button, but the green light just keeps flashing. I unplugged the set for several hours and when I plugged it in again the green light just kept flashing. Tried the reset procedure again, but the green light just keeps on flashing.
    Does anyone know what the story is with this or do I have to call Mitsubishi service?
    bmeck2003@yahoo.com
  • kclementsx3 Feb 12, 2009
    i have the same exact problem. Does any one know how to stop this green blinking light of death? Or how much this is going to cost to fix? Is it even worth it?
  • swilson929 Feb 19, 2009
  • 927 Answers
Good Day;
Cause #1 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Posted on Nov 03, 2008
My tv does not come on.A green light is flashing above my timer button. No picture.
The green light flashing is an error code. Count the number of flashes and it will tell the issue. Write back once you've counted the flashes. Also, was the TV having any issues before this? Was there a recent storm or power surge?
Oct 20, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
FLASHING RED LIGHT
Same problem as my Sony. Unplugging for 36 hours solved my problem
Dec 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
No picture, only the green light flashes on the 1080SI
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
1,503 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
