Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2032W Monitor
I lost the power supply in a move, does anyone know where I can buy a replacement or the specifications of the Adaptor and where to buy the round 4 pin input so it may be soldered Thanks
  • nickkilb Oct 22, 2008
    My dog ate the cord between the power supply and the monitor. I still have the AC cord, for what it's worth, but if you know where to find the power supply and DC cord, I would be grateful!
    President:
  • 3,130 Answers
Try these #. Sorry I cant assist more!! Good Luck 408.432.6200 1.800.733.2237 or the #s in your user manual.
Posted on Jun 20, 2006
Al2032w
This usually indicates that the filter capacitors in the power supply are not working right. When the unit is turned on they should build up a charge that lets the board power up the monitor but when they start to go out it takes longer and longer to get the charge built up. Here is a link to information on rebuilding the power supply board by replacing the capacitors, this should get you back up and running.
www.ccl-la.com/catalog/product_info.php?products_id=288
Dec 08, 2012 | Acer AL2216WBD LCD Monitor
Looking for a power supply for acer monitor al1714 can you help
you are looking for an AC power adaptor for your monitor, click on this link : http://www.amiline.com/AC-Adapter-Power-Supply-Acer-AL1714-AL1714b-LCD-Monitor-934271853.html but if you want, you can repair your power AC adaptor.
Dec 06, 2010 | Acer AL1716 F Monitor
My acer 223W monitor has a flicker or moving lines in it.
My acer 223W monitor has a flicker or moving lines in it? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Apr 09, 2009 | Acer 22" X223w LCD Monitor
Power supply
you may try to use a universal power supply adapter by APC! check with ACER web page for the your acer monitor voltage and amperes!
May 31, 2008 | Acer Computers & Internet
Acer 2032 w will not stay powered on
If you can splice wires, this will fix it. First beat the old Acer power supply to death. (God, that felt good) Then cut the wire off the old brick and splice it onto a laptop power supply that's rated at 18 or 19 volts @ more than 4 amps. Dell uses them and I used one from an HP dv2000 that cooked itself to death. The Monitor runs on less than 3 amps and is quite happy at 18 or 19 volts. By the way, the white wire is positive and the black wire is negative. Don't worry about those four pins on the plug. If you look on the case of the old brick, you'll see that the pinout is quite simple - 1 and 2 are positive, 3 and 4 are negative.
Feb 18, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Power supply
Bs more specific with your problem.
Jun 23, 2007 | Cornea CT 1810 18.1" Flat Panel LCD...
Need AC/DC adapter for monitor!
Hi inkedpandora, http://icm.computercci.com/pgi-productspec?PSO080 This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
Nov 22, 2006 | Liquid Video A170E101 Monitor
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
697 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
