Question about JVC AV-32432 32" TV
Lost Picture When we turned on the tv this morning (worked fine last night) there was no picture, just colors streaming horizontally across the screen. The audio is fine. ???
  • 84 Answers
Try tapping tv on side with palm and see if it works it might be a bad video chip
Posted on Oct 19, 2008
Horizontal color lines..
problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Jul 27, 2009 | Sony KP-51WS510 51" Rear Projection...
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Jun 30, 2009 | Orion Televison & Video
No picture
If i am to understand this correctly, this is a rear projection television. Inside there may be 1 - 3 " color " control boards that control the picture before going on to the projector. an accumulation of dust / dirt / debris has adverse affects on electronic componants, make sure they are dust free (compressed air cleans them off quite well. If using a home compressor, make sure there is a vapor filter to remove water from the airlines.)
If they are clean, and as you said you recently had the television serviced to replace the projection lamp, take the television back to the repair shop to have them determine the problem.
If you yourself replaced the projection lamp, be sure to check all connections are properly seated if you had to disconnect something, make sure they are in the proper places, and any connections are securely connected.
If all else fails, have a local electronics / television repair person check the unit for faulty componants.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
JVC AV-32432 32" TV Logo
118 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
