Question about Epson Stylus C46 InkJet Printer
C46 printer How do you chang /clean the ink pads on an epson c46 and where are they located inside the printer?
  • gpmari Nov 07, 2008
    How i can change the both ink cartridges ?
    Please give me the detail solution to change both cartridges.
    I have the problem to move the both ink cartridges on the left position tho change it.
    Tank jou for the answer.
    Gianpaolo Mari
    gpmari@cscs.ch
  • Epson Master
  • 4,338 Answers
I could not find the manual, but I hope this helps:
I'm not sure if the waste ink pads are in the same place as the c45, but i hope this helps.
Locating the waste ink pads was pretty easy. First of all you have to dissasemble the case, then remove the paper slot. To do this you have to unscrew three or four screws (at least in my c45) that keep the paper slot attached to the printer. After doing this you will see the ink pads, they are at the bottom back of the printer. Mine has four of them with an "L" alike shape.
Clean them with plain water, then let them dry a couple of hours until all the moisture is gone.
I advice you to remove both ink cartidges before doing this because an strange thing happened to me.
After removing the ink pads i cleaned the ink pad container (you'll see the little tube that drains the "waste" ink from the cartidges to the pads) then a couple of hours later i found that the container was full of ink!! C46 printer - confused1.gif . And of course, the ink cartidges were almost empty
That happened because i didn't remove the ink cartidges before doing the whole process. I have no idea why that happened but probably by removing them you'll avoid that.
Epson resetter software can be found at http://www.ssclg.com/epsone.shtml (the link to download it is located at the bottom of the page)
One last thing, to reset the waste ink counter you have to go to "Protection Counter" menu and then click "Reset Protection Counter".
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
After changing a black cartridge (epson) my stylus C46 now says that a service is needed. Help please
You just need to reset your printer's waste ink pad counter. Go to this site to download the program you need to use to reset your printer,
http://lix.in/-67f1ad
Download the C41-46 file.
Aug 17, 2010 | Epson Stylus C46 InkJet Printer
Parts inside your printer are at the end of their service life.
This message refers to the waste ink pad in the printer, when this is 'full' this message appears, You can reset this yourself by downloading the right software which you can download from here:
I have also checked the C46 is supported
Sep 03, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 green and red lights flashing, saying parts need servic
Care to read this link
http://tricks-collections.com/2008/06/reset-epson-stylus-color-printers/
Goodluck
By the way emptying the waste bin needs disassembling of the unit then washing the ink foam.
Jul 19, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
Jul 07, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Red and green lights flashing alternately
Hi there.
Under each printers there is a pad, a spunch that holds all the wasted ink. This pad is probably full. you should locate where the ink pad is and change it or clean it. By cleaning I mean getting rid of all the ink from the spunch. After cleaning or replacing the pad you shoul run a utility to reset the protection counter. I use to have a all in one epson printer and did the same. I use SSC Service utility. it helps to reset the counter. After that, if that is the problem, your printer should work again.
Good luck
Mar 30, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus c46
No... It means that your printer has reached the point where it believes your waste ink pads are "full".
All Epson printers can have their waste ink hoses redirected to an external tank and you should have no problems resetting the waste ink counter. The problem you will have though is that the C46 has no known instructions for locating and redirecting the waste hose (and I know of most models).
I found this link which may provide some help.
flickr.com/groups/techrepair/discuss/118485/
(You'll have to copy paste that to your address bar).
It's not easy but get some rubber gloves and take your time... it's not like you've anything to lose. Best of luck and remember there are forums and discussions on this sort of problem all over the web now.
Jan 27, 2009 | Epson Stylus C46 InkJet Printer
Red & Green led is blinking continiously after carriage initial.
The Waste Ink Pads are deemed to be saturated and should be replaced. You can overcome this problem temporarily bu using the SSC utility - download from
and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual.
Jan 09, 2009 | Epson Stylus C46 InkJet Printer
Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46
Oct 07, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
239 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
