Question about Cuisinart DLC-10S Pro Classic Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
  • 8,596 Answers
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Posted on Jan 17, 2009
  • Kalana May 21, 2011
    Awesome! That fixed it - thanks so much!
My cusinart pro custom 11 the machine is running but the blade is not spinning not even manually
Have you attached everything properly?
They have a safety feature that keeps them from running when the basket and top are not attached or not attached properly.
Nov 28, 2015 | Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
MACHINE WON'T TURN ON AFTER BEING USED
I am guessing that something is not seated properly. Make sure the bowl clicks when turned...drops the pin in. Make sure the top is ("clicked in") locked. If you poured something out of the bowl and went to re-use it, make sure the blade is seated properly; make sure there is no food caught under the blade hindering the blade to be seated. Everything must be locked in correctly to operate safely.
Mar 25, 2014 | Cuisinart DLC-10S Pro Classic Food...
My Cuisinart Pro Classic is leaking! When I tried to make corn pudding at Christmas, something I've done many times before, the liquids poured out all over the counter. Everything seemed in place and the...
it is either the seal around the blade shaft that is worn (but if it is worn so much that liquids can leak, then you probably heard the machine vibrate more than normal or sound screechy). Or it is the gasket at the bottom of the container that is not seated well or is out of shape. Goodluck, Macgivor
Jan 16, 2010 | Cuisinart DLC-10S Pro Classic Food...
How to us cusinart 11 cup food proceessor for chopping. cutting.
You can download the user manual for the DFP-11 from
http://www.cuisinart.com/parts/food_processors/dfp-11.html
Click on the "download user manual" hypertext link on the right under the processor picture. You need to have Adobe Reader loaded to be able to read the manual.
Please rate this solution. Thanks.
Oct 22, 2009 | Cuisinart DFP-11 Deluxe Food Processor
I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-10S Pro Classic Food Processor Logo
618 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
