Question about Smeg Refrigerators
I have a red smeg fridge freezer with many scratches on the doors which i would like to repair if possible, someone has suggested tcut, but i'm a little apprehensive. Thanks
  • nisbetc Oct 19, 2008
    Many thanks, I'll try this - couldn't be any worse than it already looks!
  • 417 Answers
T Cut removes paint as it is polished on to a surface, it is really only suitable for removing oxidization from auto paints.
A better solution is to use a coloured surface polish also used on car paints this will not be abrasive and is available in red from auto stores
Posted on Oct 19, 2008
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
SMEG fridge freezer, freezer door was left open and it defrosted. we have turned the applience on again freezer is contantly triping and it is not working. red light is on constantly. please help
the relay is timing out this was caused by over run try turning off for 1 hr to let it settle and decompress if it does the same fit a new relay and try if that does not work it meens the compressor has gone expensive repair
Nov 25, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Smeg 50's stle fridge
we had so much frost that the fan couldnt turn to keep freezer cold. we defrosted it and it ran fine. someone left the door not shut all the way and tahats how it got wet and then refroze.
Dec 22, 2007 | Smeg FAB28
SMEG FAB28
This is a known problem with these fridges. The only fox is to replace the fridge.
Jun 16, 2007 | Smeg FAB28
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
392 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
