Fuse on circut board blows when replaced each time power switched on.
  • k-payne2 Oct 20, 2008
    would the fault be in the main circit board,or could it be anywhere?would a t.v. repair man easly find this fault.
  • 417 Answers
You have a fault on the circit board, you need to identify the faulty component and replace it or call a tv repair man.
Posted on Oct 19, 2008
  • ashburton Oct 20, 2008
    Yes, the fault could be anywhere but a competent repair man should be able to locate the fault fairly easily.
Power Windows and Turn Signals Not Working - 15A Fuse keeps blowing
If a fuse keeps on blowing there is a short in the wireing to that circut, Your best bet is to take it into a auto electric shop to be check out,
Nov 28, 2012 | 2005 Subaru Impreza 2.5
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Ignition switch fusible link blows after starting and running for a short time
ARE YOU SURE A FUSEABLE LINK IS WHAT BURNEB OUT AFUSEABLE LINK IS A PEICE OF WIRE ABOUT A FOOT LONG THATS MADE TO BURN OR BLOW LIKE A FUSE AND USED ON MAIN CIRCUTS THAT RUN OFF THE BATTERY STARTER IGNITION ALTORNATOR ITS CLOSE TO BATTERY AND YOU CAN;T REPLACE WITH REGULOR WIRE YOU NEED TO CHECK ALL MAJOR POWER SYSTEMS THINGS THAT HAVE LARGE WIRES RUNING TO THEM FROM THE BATTERY
Oct 13, 2010 | 1998 Chrysler Sebring
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Photocopier fuses hi my name is redha i would to have a definition of fuse in the photocopier in general the location and tha function ASAP Please Thanks
Redha,
Fuses are located on the power supply and some control boards.
In general fuses are used for circut protection when the load exceeds what the circut is capable of handling the fuse will blow to hopefully protect the circut and the board. This is a very broad definition.
Hope this helps
Apr 18, 2010 | Gestetner DSc338 Copier
New power window switch is not working, don't know where fuse/relay is located
usually the power windows in on a circut breaker fuse. if it blows it resets its self after cooling down. use a test light to see if you have power on any of the wires on the back of the switch. if you have power chances are you have a bad motor for the window. asuming that you replaced the front drivers side switch. if that wasn't the one you replaced say the back pass side switch odds are its the drivers side front set of switches bad. hope this helps you.
Mar 11, 2010 | 1999 Volkswagen Cabrio
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dell w4201c burning fuse...
hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Jan 10, 2009 | Dell W4201C 42 in. Plasma HDTV
Brake lights and crusie don't work
1ST THING TO CHECK IS THE STOP LAMP FUSE . FUSES LOCATED LH SIDE UNDER HOOD. THIS FUSE ALSO POWERS THE ACC. CIRCUT IN TRUCK. ALOT OF TIMES, LAP TOPS, DVD PLAYERS ETC. OVERLOAD CIRCUT & FUSE BLOWS.
Oct 25, 2008 | 2002 GMC Yukon Denali
My tv power does not come on
This set uses a switching power supply. Usually when there is a short on the output side of the switching transformer the supply will just shut down and refuse to operate but normally will not blow a fuse. If the fuse blows suspect a problem with something shorted on the input side of the switching transformer such as I801 regulator IC, diode bridge D801,or other shorted component. Perhaps someone else could tell both of us any other part that could cause the regulator to blow and should also be replaced to prevent regulator failure in the future.
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
