Question about Samsung SyncMaster 720N Monitor
HI, I HAVE A SUMSUNG SYNCMASTER 720N MONITOR, THE BRIGHTNESS OSD HAS JUST STARTED TO TURN BRIGHTNESS UP TO 100 AND PERMANATELY STAY ON SCREEN , IS THERE A RESET BUTTON AS SUCH OR A WAY TO MAKE IT GO , IV PRESSED THE BUTTON BUT IT POPS BACK UP, RIGHT IN MIDDLE OF SCREEN, THANK YOU IN ADVANCE pAUL
  • carain Nov 19, 2008
    Ik have the same problem and the buttons are not stuk, could it be dust inside the monitor?
    Maybe some foam cleaner (anti static) would help?!
    Is there anyone who has another solution?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi check if ur contrast button is not stuck,if ur button is ok , change ur mainboard
Posted on Oct 19, 2008
Brightness bar stays in the center of my screen Samsung SyncMaster 731N
I'm Adam and i'm a computer-technicien!
I should do these 2 things do hide this brightness bar:
-You can click the MENU button again!
-You can simply disconnect the power-cable from the monitor and
let it unplugged for like...10-15 seconds!
-You can remove the button with a screw-driver and take the
little plastic on the second button.
If this all doesn't work...
I can recommend you to send a email to SAMSUNG with this info:
-Name:
-Date when you bought this product:
-When did this start:
-And your CPU information:
If this all doesn't help...
You ned to install a driver called 'Syncmaster 720n/730n driver'!
Thank you,
May 25, 2011 | Samsung SyncMaster 720N/731N
My brightness menu is locked on the screen and my monitor buttons aren't working .. I'm having a silver Samsung Syncmaster 720N.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 10, 2011 | Samsung SyncMaster 720N Monitor
HOW TO DELETE BRIGHTNESS BOX FROM MONITOR ON SAMSUNG SYNCMASTER 720n
If your trying to get out from the brightness option. Please follow this steps...
Go and click this manual, then at the left side of the manual look option that says for "Adjusting your monitor" then look for user controls.
I hope it helps you a lot :)
Feb 03, 2011 | Samsung SyncMaster 720N Monitor
Probably not only because I found several forums and the same claim as is my case .. initially function to adjust the brightness automatically .. 100% ... like I keep the button pressed continuously .....
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=720N
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Samsung SyncMaster 720N Monitor
The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
May 27, 2009 | Samsung SyncMaster 720N Monitor
Picture size problem
click start,control panel,display,settings and set your screen resolution to what you need
May 23, 2009 | Samsung Syncmaster 17" 720N Monitor
Samsung Monitor 720N
check the resolution of the system make it as 600*800.
Jan 06, 2009 | Samsung SyncMaster 720N Monitor
On screen controls have a mind of their own
The buttons are stuck - If the screen is out of warranty then i would take it apart and see if he buttons can be unplugged or cleaned up.
If in warranty Samsung is excellent with repair service. - Depending on the model LCD its either 1 or 3 years warranty.
Dec 30, 2007 | Samsung SyncMaster 720N Monitor
Popup on monitor screen
i had the same problem.i called up the service senter of samsung and they were like, press the menu button and hold it for some time.immediately press the auto button.this would do auto lock.i mean auto adjustment lock.that solved the problem somewhat in my monitor.its not a permanent solution but it can help...
Jun 23, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung SyncMaster 720N Monitor Logo
841 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
