Question about Peavey CS 1400 Amplifier
Problem with my Peavy CS 1200x power amp
I facing a problem at which my amplifier trips without load. only one channel is tripping. it becomes very hot after i swicth it on for 20 mins and trips on high temp. this happens without any input singnal and output to speakers connected.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
1200x with over heating output...does not care if it has a load unless it is too low,(Scott is wrong)..you have a leaky output, or a triac firing and clamping down the voltage to the speakers..the foldback shutdown may also be leaky, but these usually cause it blow fuses, and these get damaged by bad outputs or running the amp into shorts..since this amp has some really high voltages in it I suggest you take it to a shop before you KILL YOURSELF!
Posted on Dec 16, 2014
    Genius:
  • 1,175 Answers
Hi...
Not complicated.
You need to have the outputs connected to a SPEAKER or Load
These amps DO NOT like no load conditions.
Hopefully the amp channel is still good after overheating
Posted on Mar 01, 2009
    President:
  • 3,130 Answers
The Idle bias or channel offset circuit is not functioning and the longer you wait before you have it repaired by a pro, the more its gonna end up costing you. At this point its probably just a small bias diode or even an channel bias alighnment .Good Luck
Posted on Jun 20, 2006
Peavy bandit 110, unit powers up fine and plays ok then intermittently output drops way down. You can barely hear it. Sometimes it comes back by itself or by repowering. This happens on any input or...
You have some semi-conductor device that is effected by heat and is faulty. When it get's to hot it switches off, then it cools down and comes back to life. If this is a stereo amp and it happens on both channels then you are looking for a device that is used by both channels. The only way to find out which part is to use Servisol Freezer Spray on suspect parts. You wait while it plays up and then blast (only one at a time) the suspect part with the spray. If it comes back to life you have found the part that's faulty.
Oct 16, 2013 | Peavey CS 1400 Amplifier
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
May 18, 2012 | Sony Xplod XM-ZR704 700W 4/3/2-Channel Car...
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
My europower ep2500 amp the braker trips when I power it on
Hi,circiut braker trips only when the load on it is to much.
That is carry what is bigger than it watt, or can not carry too well. If you have another amp., you can put some load on that to reduce to braker always tripping off.
If that is the only amp. you have in what you are doing, just reduce the amp. volume to half(setting at 12 O CLOCK). it will work, but will not be too loud as before.
Take care.
May 21, 2010 | Behringer EUROPOWER EP2500 Amplifier
How work peavey cs 1400? is good
I just added a CS2000 to my rig and it is powering a pair of Peavy SP2s and a pair of SP118 with no problems at all and it sounds great. The CS stands for Commercial Series and is the workhorse of Peavey. I highly recommend them.
Aug 21, 2009 | Peavey CS 1400 Amplifier
4200
are you using a right load for the amplifier. what the rated output power of your amplifier. and know the output of your speakers.
well sometimes it protects you from being deaf.. for maybe its too loud so it goes to protection mode. dont know if -23 could make a person deaf.
well I hope I helped you with my solutions.. ^.^ please dont hesitate to respond us..
Jan 20, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Plug in Numark mixer & twin CD player to a Peavy CS 1200 x amp. There are diagrams but im lost
simple.numarks outs to peavey's inputs.probably rca's to quarter or rca's to xlr's
Dec 08, 2007 | Audio Players & Recorders
Boss 2500d gets hot and trips off and on every 5 mins...
If you are bridging the amp then you must DOUBLE the "ohms load" that is specified. I.E. If you need 4ohms per channel, then when bridged you would need 8ohms per bridged channel. If your load is indeed correct then you have a fried output probably. Try to run it without any speakers on it. If it still gets hot then you for sure have a fried amp. All the symptoms you decribe sound just like you have too much of an "ohms load" though.
Aug 01, 2007 | Boss Riot 2500D Car Audio Amplifier
733 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
