Question about D-Link DGL-4500 Wireless Router
Problems connecting to DGL-4500
I recently installed a DGL-4500 router and am getting some odd issues, both of my vista machines can connect with no problem (1 wired and 1 wireless) my sisters computer XP sp2 can also connect with no problem as well as my xbox but my mom and dads computers cannot connect unless we reset the router each time they restart their computer. it shows them connected but the internet just dosent go through till the reset. both of these machines are running XP sp2 and have never had issues connecting in the past. ive tried just about everything i can think of, assigning an ip in the tcp/ip settings and so forth.
any ideas?
  • D-Link Master
  • 6,487 Answers
This can be a firmware problem so upgrading the firmware of the router should fix this issue on it, so I advice you to upgrade to the latest firmware of your router, you can get it from Dlink web site...
Posted on Nov 07, 2008
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Jul 29, 2011 | D-Link DGL-4500 Wireless Router
I just bought a D link dgl 4500 router and it works fine most of the time. Tonight and one other night before it will reset my wireless network almost every five minuets. I have reset both the modem and...
Make sure you have the latest firmware as this might help with your dropped connections. Also try to make a DHCP Reservation for each computer connected to your network (p. 32 in the User Manual), as that can also help prevent dropped connections.
Download the latest firmware ver. 1.23NA to your local computer. Connect your DGL-4500 router via a wired connection (ethernet) to your computer and install the firmware update following instructions in the user manual.
Firmware link:
ftp://ftp.dlink.com/Gateway/dgl4500/firmware/dgl4500_FW_123NA.zip
Here is the PDF link to the User Manual:
Feb 23, 2011 | D-Link DGL-4500 Wireless Router
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the network-port on the cable-modem to the 'WAN' or 'Internet' port on the router.
Use another Ethernet cable to connect the network-port on your computer to one of the 4 'LAN' ports on the router.
Turn the cable-modem on.
Wait for its lights to settle-down to a repeatable pattern.
Turn the router on.
On your computer, you should have Internet access.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
Feb 05, 2010 | D-Link DGL-4500 Wireless Router
I am trying to get my laptop connected wirelessly to my dgl-4500 router. It keeps saying connection time out?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 11, 2010 | D-Link DGL-4500 Wireless Router
I have DSL modem and before that I was connected through the internet by cable and it worked on my both my computers (Alienware and MAC) with the router DGL-4500. Now I changed internet providers and have...
Check the IP address of the computer.
If you aer getting the Ip address on the computer then try to ping the router.
You have changed the ISP. there is difference between the cable and DSL service provider. settings are different.
You will need to set up the router from the start.
Click Here for more info about how to set up the router
Oct 22, 2009 | D-Link DGL-4500 Wireless Router
How do i hook cables to download new firmware into my dgl-4500 from computer to router
  1. I assume you downloaded the newest firmware (version 1.21NA) from this site.
  2. Save or move it on your desktop so it's easier to find.
  3. Connect your router to your computer with an Ethernet cable.(If you're not sure what it looks like, see here.)
Do not upgrade the firmware over a wireless connection!
On the same page, look at the FAQ's. there is an entry called "How do I upgrade the firmware on my DGL-4100/DGL-4300/DGL-4500?" It is a description of the upgrade process itself and will walk you through the steps.
I'm just amazed that they miss a really important warning. Do not unplug your router or close the browser on your computer until this process is finished. This can render your router useless and you will have a nice, expensive doorstop.
When the upgrade process starts, go have a coffee, do your dishes, whatever, but: Leave the router and your computer alone! Wait until the router's reboot is completely finished.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 09, 2009 | D-Link DGL-4500 Wireless Router
Slow or intermittent wireless/then disconnected
thats not enough info. it could be a dead router, too much interface, incorrect settings. try the router at your friend's house. if it works then its not your router. download a software called network stumbler, install it, to run it in vista right click it and click run as administrator. find the channels your router and other routers in the neighborhood are using. if they are the same then its an interference issue and if not then your router has incorrect settings.
Jun 04, 2009 | D-Link DGL-4500 Wireless Router
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
Connection
Hello Krmn,
Are you running windows Xp or Vista ?
George
Sep 24, 2008 | D-Link GamerLounge DGL-4300 Router...
D-Link DGL-4500 Wireless Router Logo
275 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
