Question about Dewalt DW746X 10" woodworker's table saw with rai
Dewalt DW742 won`t start
Pushed the start button on the machine the blade jerked to start and then stopped and now getting no response from either start button.
  • gooseswan Mar 31, 2009
    have same problem with elu flip saw
    Novelist:
  • 99 Answers
These machines have an induction motor and need a capacitor to give it a kick start. Is it humming when you push the button? If so I would check the capacitor and you will probably find the fault there. Otherwise it could be a problem with the table switches. When the table is flipped it pressesd against a button which tgells it which on switch is operational. If something has blown there it would disable both buttons.
Posted on Oct 26, 2008
Same problem with elu can you repair them at a reasonable price if so who can do it
Posted on Mar 31, 2009
My brand new dewalt cordless chop saw wont work when i pull the trigger the blade jerks and the light and motor gos dead ,thats happening with batteries and inverter
The first thing I'd check is running it with the blade off . Could be locked up somehow. I'd also check the spindle lock . If it's stuck down it locks the gears up .
Sep 18, 2017 | Dewalt Saws
How do I get a broken blade out of Dewalt DC330?
Do the same procedure on how you installed the blade.
Sep 14, 2014 | Dewalt 18v 18 Volt Cordless Xrp Jig Saw...
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
I have a circular saw that is locked and the blade won't rotate its brand new how do you free the blade?
Its sounds like the blade lock button is depressed.
looking from the rear of the unit, you should see a button between the left side of the handle and behind the blade shield.
check that. it probably is locked in the depressed position or it may be damaged.
I hope this helps.
May 18, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Mar 22, 2009 | Dewalt DC385B 18v. Cordless Bare...
Dewalt DW746X 10" woodworker's table saw with rai Logo
1,767 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
