Question about Philips Magnavox Learning Universal Remote
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
PHILLIPS TV&PHILLIPS REMOTE. TV IS TURNED ON W/ REMOTE AND/OR MANUALLY TURNED ON. IT ONLY STAYS ON A FEW MINUTES THEN TURNS OFF BUT THE RED LITE IS STILL LIT ON THE TV. I'VE PLAYED AROUND WITH THE MENU BUTTON BY CLICKING IT SEVERAL TIMES WHEN TV IS ON THIS SEEMS TO SOMETIMES CORRECT THE PROBLEM &THE TV STAYS ON W/OUT GOING OFF BUT NOT ALWAYS. I THOUGHT IT MIGHT HAVE SOMETHING TO DO W/ THE PROGRAMMING. I CAN'T FIND MY OWNER'S MANUAL.
  • Anonymous Oct 22, 2008
    actually this just started- I am wondering if it has something to do with the new changeover to the new tv system - my area has changed over early and this has JUST started - our remotes worked until now
  • TooQuiet Nov 06, 2008
    I just put a video in and now my TV won't allow it to be ejected. Tried the remote and the power button on the TV, but I get about 2-5 seconds of sound & picture before it goes off. I waited several hours to try again. The TV still turns off immediately. The plugs and wall sockets are working. I have a 12 year old Sylvania with no prior problems. Any suggestions?
Lost my code book need the code for a phillips universal remote for a konka tv.
Posted on Oct 23, 2008
Kids stepped on remote.tv wont stay on-it turns off immediately. tried resetting.still turns off. wont stay on.
Pull the batteries out of the remote, and turn the TV on manually if you can. If it still goes off, your problem is not in the remote.
May 22, 2015 | RCA Audio Players & Recorders
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Code for p1300ntv to work with directv remote
You can "manually" find your code by  1. pressing tv button on the remote 2. press and hold setup until TV button blinks twice 3. press 991, the tv button should blink once 4. slowly press and alternate the power and tv buttons until tv turns off.   5. press setup to lock in the code when tv turns off.
hope this helps,  j
Jan 14, 2009 | Disney 13" TV
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Problems programming TVTECH universal remote controller
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Jan 06, 2008 | RCA RCR412C Remote Control
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips Magnavox Learning Universal Remote Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
