Question about KitchenAid KGSA906P Gas Kitchen Range
KGSA906PW - Replacing Oven Door Glass
Hi!
We have this unit and during a move, the oven door needed to be removed and was subsequently dropped - shattering the glass. We need a diagram/service manual and the part number in order to replace the glass.
Also, after reading the other users issues with overheating while self-cleaning and the various problems that result we were wondering if there was a preventative fix to this design flaw?
Thank you for your help!
5 Suggested Answers
  • 833 Answers
SOURCE: KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
  • 409 Answers
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Posted on Sep 13, 2008
SOURCE: how do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Posted on Sep 26, 2009
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
My GE Profile electric kitchen stove has the oven door open but the locking latch engaged which prevents the door from closing. The panel light is blinking that the door is locked. Solutions???
Hello, Lou -
Try this:
- Switch the circuit breaker for the oven to Off.
- Wait a full minute.
- Switch the circuit breaker back to On.
If those steps do not work to solve the problem, the problem could be caused by the micro-switch for the door lock assembly signaling to the oven control board that the door is locked. You will need to remove the door lock assembly cover. Before doing that, make sure the oven is unplugged from the electric outlet. You will need to pull the oven away from the wall.
Then, disconnect the door lock assembly wires from the micro-switch (make sure you note where the wires connect) so that the door lock assembly can be moved back to the open position.
Then plug the oven back into the electrical outlet or flip the circuit breaker to On. Test the oven to determine if it runs on broil or bake. If it does, the door latch assembly will need to be replaced.
If the oven still doesn't work and the control light continues to flash indicating the door is still "locked", then the electronic oven control will need replacing.
See this video:
https://www.youtube.com/watch?v=JroL8UPDkgI
If you do not feel comfortable following the steps for removing door lock assembly and the subsequent steps, you will need to arrange for a repair technician to come to your home to determine what is wrong and make repairs.
Best wishes.
May 11, 2018 | GE Kitchen Ranges
How to remove glass from oven door
didnt specify unit -generic answer --remove door and place on flat surface or floor --un screw the inner panel --remove glass retaining clips [if present ] -replace glass --replace panel and then door done one of the videos in link an assist you
replace oven door glass Yahoo Video Search Results
Oct 17, 2016 | Ovens
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How to I clean between the glass door panels
Why? Mine looks to be almost a "sealed" panel, similar to the sealed Thermopane for windows and Doors, only the outside surfaces can be cleaned. If there is a decorator cover, that can be removed via the surround and remove. But I'd leave it alone. Consider it's age, your age, when will you move or not move, when or if you will replace it, or remodel. If it's a critical issue, I'd look for a nice looking used replacement door.
Mar 03, 2015 | Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Open Questions:
KitchenAid KGSA906P Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
