Question about Hotpoint WD52 Front Load Washer / Dryer
Hotpoint 9912 washer/dryer
I have just taken the lid off and seen that there is some blackening on the circuit board, can i replace this myself?
  • lynne rosendale Jun 20, 2006
    thanks, this problem was added after my original quaestion regarding the circuit board, it is listed under circuit board.
  • 641 Answers
What exactly is your problem ? Some blackening on the circuit board doesn't mean it should be replaced. In case the board should be replaced (you can do it yourself), you should understand first what cause it to become blackening. Let us know with more details and we will do our best to support you. Good luck !!
Posted on Jun 20, 2006
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the...
hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint 9912 washer/dryer & whilst using today there was a clunk & the drum stopped turning, we have replaced the brushes but the motor still does not turn
Could be that you have a faulty motor, check the armature for signs of shorting or burning, also make sure that the brushes are contacting the armature, check the connections are o/k in the motor plug, pull on each wire individually, if still no go, and everything else is working o/k, then it look's like you will have to replace the motor.
Please rate my comments.
Thanks
Sep 25, 2009 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD860P trips rcd within second of being switched on
the usual problem with tripping is the heater of the dryer box has become loose and touching an earth.
if you take the lid off you will see the box on top of the drum.
with the electric off you can look for loose/disconnected wires and wiggle the 2 metal tabs that are the ends of the heater, should not move.
you may be better with an engineer visit if it's not an obvious fault.
Feb 25, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer
your dyer stat has gone you can see this when you take the lid off make sure you unplug the machine its normaly the white one it has two wires the other one is black that's the clod one leave that only take out the white one and go down to your appliance shop and ask them for one take down the model of your machine first onece replaced job done
Jan 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Circuit board
It sound like a malfunction circuit board issue that shouldd be replaced.
Jun 20, 2006 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD52 Front Load Washer / Dryer Logo
59 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
