Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I can not get the coffee grind to come off. How do i get it off so i can clean.
  • swoodall Nov 09, 2008
    ditto - does anyone know?
  • Anonymous Apr 07, 2009
    my grinding basket is totally stuck
  • 8,596 Answers
It should just pull off, but the DGB-600 has a tendency to get the stuck basket syndrome you are describing. Try icing the grind basket down and try to remove again after 15 mins. Replacing the unit will not help in this case, b/c your replacement will eventually develop the same problem.
Posted on Dec 17, 2008
Coffee is getting stuck in the shoot between the grinder and basket so coffee is very weak
Try using a bottle brush and cleaning out the residue from coffee grinding. Coffee grinds build up because of the oils in the beans. I clean mine twice a week and it works great.
Mar 05, 2016 | Kenmore 12-Cup Coffee Grinder and Brewer,...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
I clean with rice and it grinds coffee beans. Then I have to grind moRE RICE TO GET IT TO GRIND COFFEE AGAIN
Instead of rice, fill container about half full with regular table sugar. Grind that for 10-20 seconds. You should not only get coffee flavored powdered sugar but the sugar will soak up the flavors from your grinder.
Then simply clean as you normally would. Works great!
Mar 19, 2011 | Starbucks Barista Burr Grinder
Cleaned the machine and now the grinder does not grind any coffee, it sounds like its grinding but it keeps showing that I need to add beans after it attempts to grind. yes it has beans in it
Did you cleaned the grinder with any fluids? This will not help , the blades got wet and coffee grounds are stuck (cemented) on to the blades.You will have to cleaned the blades and KEEP it DRY.
May 25, 2010 | Saeco 00041 Espresso Machine
Coffee grinder was not grinding. Have cleaned out the grind passage, but will then grind once and block again. The coffee is not getting through the drop chute. What makes this shute open? why is it not...
Yes you are correct one posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Apr 10, 2010 | Saeco Royal Professional Espresso Machine
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
389 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
