Question about GE WSXH208A Front Load Washer
My washer will not start!!
I have the GE WSSH300G0WW washer and I cannot get it to start. I've unplugged it and plugged it back in, and nothing. Can somebody please help me?
    Problem Solver:
  • 7 Answers
Does the start/pause button flash and then the door unlocks? I had that problem too. This is what I did. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Posted on Oct 26, 2008
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
I have a GE model wssh300g0ww washer and when I opened the washer the water was still in the washer and when I tried to have it stpin it made an awful loud noise and does not appear to do anything at all. ...
Hi, You need to inspect the filter. Its at the bottom in the front. Take a pan and place it under filter handle. Slowly turn it counterclockwise, water will start to come out. Empty pan when partly full. Repeat until no more water come out. Unscrew filter and remove. Clean, inspect cavity and replace. Hope this helps.
Jan 17, 2011 | GE Washing Machines
My wssh300g0ww ge washer dose not do the final spin?
I have the same problem. We have replaced the front memory board, checked for clogs, all the connections and still no luck. Did you ever find a solution? I am very fustrated.
Jan 13, 2010 | GE Washing Machines
GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Apr 29, 2009 | GE WSXH208A Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
GE Washer stuck on final spin cycle
Mine is also stuck on spin, but unplugging has not helped???
Apr 06, 2008 | GE WBSE3120B Top Load Washer
Front load washer model #WSSH300G0WW
push the button again...... its a toggle button the delay is either on or off.
Jan 21, 2008 | GE WSXH208A Front Load Washer
Washer does not spin
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Dec 12, 2007 | Washing Machines
GE WSXH208A Front Load Washer Logo
734 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
