Question about Lands Phones
RCA 25250 2-line DECT 2.0 NEW CALL counter not working. Ever heard of this problem? Phone's only been around since May 2008. Stores that carry the phone have only returned units. Kinda makes ya wonder . . .
  • macke004 Dec 19, 2008
    Sorry, I already called tech support. They told me they never heard of this problem. I bought four phones. Returned all 4. Needless to say I could tell (after opening them) that 3 of 4 phones had previously been returned. Probably due to the same problem. Maybe a "revB" will arrive on the market in 2009 and fix the software issue?
  • Anonymous Jan 08, 2009
    Keeps indicating an incoming 'Unknown Call' every 30-seconds, but no call is actually there. Very frustrating!
Just bought my unit and handsets. Same issue. No resolution yet. Will call the Thomson tech support to see if they can help.
Posted on Dec 18, 2008
How do I fix a rca 6.0 cordless phone which has a blank screen but phone works
Most likely you cannot. The screen is either damaged or the display drivers are bad.
Oct 08, 2015 | RCA 25211 2-Line Dect 6.0 Cordless Phone...
How do I record an outgoing message for my RCA 25250 Answering System?
Call your number from that phone you should record that way from the prompts
Jan 22, 2015 | RCA Lands Phones
Why did my display disappear?
Possible electrolict capacitor defeated. Replace is needed.
I suggest make a electronic tech consulting. Good Luck !
Jul 30, 2014 | Compaq (252608-001) Motherboard
RCA visys dect 6.0 Line 2's light is lit and no dial tone. All handset are in off mode. Only Line 1 is available
Are the phone cables correctly connected to the base unit? Try a new cable for Line 2, if you have separate L1 and L2 jacks. (If the lines are integrated in one jack, make sure to use a 4-conductor RJ11 cord.) I assume the service hasn't been cancelled for line 2 and that you are at a wall plate with both lines.
If you have separate jacks, I like to use a different phone to check the jack. (A simple old fashioned corded, single-line phone is useful to check for a dial tone.) Try checking Line 2 at another jack, if you have one.
If you do not have a dial tone, find where your service comes in. Open the box and look at the terminals. If you are lucky, you have an RJ11 port. Plug in your test phone in to the Line 2 connection and listen for a dial tone. If there is no dial tone, contact your telephone company. They will fix an outside line problem for free. (Mice and other things can damage the wiring. A lightning strike could damage a filter if you use the line for a high-speed internet connection.) If the terminal doesn't have an RJ-11 plug option, you will need to ask your telephone company to test the line.
If you recently had work done on the phone line, check for any wires that are loose. When we got our phone line upgraded to fiber optics, one of the telephone jack lines didn't get connected to the terminal in the new box. We found the wire behind the vinyl siding and got signal as soon as the wire was reconnected.)
If you have a dial tone at the box and no wires are obviously disconnected, you'll need to trace the wires inside to find a broken connection. If one jack worked for Line 2 and another didn't, check inside the wall plate. There are two wall-plate styles. The ones with a keystone jack needs the conductor wires pushed down into the correct slots. A punch-down tool is available from most hardware stores in the wiring section. The screw terminal type requires the individual wires to be stripped and then secured. The correct terminal positions are shown here: http://www.lanshack.com/wire_phone_jack.aspx . Otherwise, you need to trace the wires in the walls to find the break in the continuity. Your phone company will do this for you for a fee. If you have a line filter inside, try replacing it.
I hope this helps.
(I've called the phone company several times when we lost one line. Mice and lightning damage to the filter have both been culprits.)
Jul 08, 2013 | Lands Phones
I need to delete messages I have all ready read
Since you didn't say the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 04, 2013 | Uniden DECT 6.0 Cordless Telephone...
Hello, I am looking to replace my Uniden cordless phone battery EXA14248. Do you have it??
I have searched various stores which carry battery replacements.I even searched uniden.com .We had the same problem with our old phone.Your phone seems to be outdated enough so that there are no replacement batteries.Us too.I think the makers do it on purpose to sell newer phones as much as possible.Wish I had better news but those are the facts.The new technology is DECT 6.0 phones which actaually works at 1.9 GHz.Kind of strange since the previous products were 5.8 GHz.But DECT is supposed to have wider range to walk around your house with,clearer sound and a couple of other "advantages".If you do decide to buy DECT,do some research.There are forums all over the web where people give opinions/reviews of ones they have already bought and are using.Just google DECT phones and all kinds of stuff appears.AT&T's seemed to have the better reviews but there are a couple of others which rated well also.I have had numerous Unidens,and you think they would improve,but I have been disappointed and will never buy another Uniden,however the decision is yours.Wish I had better news.Good luck! Greg
Aug 11, 2010 | Uniden EXA14248 Cordless Telephone
Need manual for model 2525
RCA has 25250 and 25255 part numbers. If that's the one, here's a link to the rca.com website. The manual link is under the picture http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=0&idproduct=21
Carl
Feb 22, 2010 | RCA Lands Phones
RCA 25250 can I record a different message for each line of the 2
hi... ya u can record it..... no doubt in that...
thank u rate me
Feb 09, 2009 | RCA 25250RE1 2-Line Cordless Phone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
