Question about Hotpoint WD52 Front Load Washer / Dryer
Circuit board last week i put the belt back on and although it did sound as if it was slighlty slipping, it washed ok. now the drum doesnt turn and the circuit board keeps doing a repeated click like it is stuck. it filled up with water ok and it drains if you move the dial but the in between bit is where the board just does this clicking. is is a hotpoint 9912 washer/dryer.
  • 641 Answers
It sound like a malfunction circuit board issue that shouldd be replaced.
Posted on Sep 04, 2007
SOURCE:
Frigidaire GLW51439FSO top load
have you had the back of the machine off if you know how to do this take back off and then try washing machine have a look to see if the belt is slipping on the drum could be that either the drum bearing has gone or that the motor has been overloaded and needs replacing also could just be the belt first of all i would take the back off and then try machine look where the belt goes from motor to the drum check if it is slipping if not slipping open the front door and try turning the drum by hand to see how much resistance there is on the motor shouldnt be to much after you have done this let me know the outcome and i will assist you further ok ill do all i can for you but remember i cant see what your seing so you need to explain in as much detail also other experts will see what you are saying and will also offer assistance but we need as much input from you as poss ok let me know
Nov 26, 2007 | Frigidaire GLTR1670A Front Load Washer
Creda 37761 problems drum will not turn heating up
OH OH SOUNDS LIKE BAD WINDINGS ON THE MOTOR, HAD THIS PROBLEM LAST WEEK , THE MOTOR WAS SHOT AND WOULD NOT TURN THE DRUM, I TESTED IT WITH MULTIMETER AND MANUALLY, BY OPEING UP AND TAKING BODY OFF THE DRYER, remove the drum and belt, JUMPING THE DOOR SWTICH, AND THEN STARTING THE DRYER, BINGO It the motor STARTED RUNNING, but when I put body, drum and belt back on BINGO no running or turning.
Sep 14, 2014 | Dryers
I have a servis easi-logic washer/dryer 1300rpm, the drum wont turn if laundry is inside but turns o.k when empty, it drains if put it on spin but does not turn the drum
This sounds very much like the belt is slipping or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. Ours for a Bosch cost GBP250- but it's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 24, 2011 | Washing Machines
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Tumble dryer not turning with heavy load
It could be the problem. Check first to see if belt is tight enough and not slipping on drum. The spindle or axle the drum rotates on could be worn out. Try lubricating it if you can.
Dec 16, 2008 | Zanussi TC7102W Electric Dryer
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hoover washing machine HF7160E
I am a recently retired appliance engineer of 20 years, and this at first sounds like motor carbons, the belt needs to be placed on from the bottom motor pulley first the onto the drum pulley last, not easy to describe in words, anyway start with the carbons, then if they ok there is a module (main PCB circuit board) normally on Hoover washes located top of machine inside front right corner in a plastic casing, look for burn marks. work safe with electrics, always unplug first
Sep 09, 2007 | Hoover HF7 160E Front Load Washer
Hotpoint WD52 Front Load Washer / Dryer Logo
262 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
