Question about Akai LCT3701AD 37 in. LCD Television
Mono/stereo sound It jumps from one sound to the other and sometimes there is a huge sound difference and it sounds terrible when it jumps from one to the other. How can I make it go from mono to stereo sound but my surround sound on the t.v. someitmes helps but not always.
    New Friend:
  • 74 Answers
You should read the owners manual, as im not familiar with this model. It should tell you what you need to know there.
Posted on Oct 20, 2008
No sound on 4 out of 17 stations. I've been into all the menus, the only difference I can see is that the 4 silent channels are in mono, all others are in stereo
the mono could be a red herring, the TV will toggle to stereo when it senses the Nearly Instantaneous Carrier And Modulation signal (NICAM) and as there is no sound it will not be getting that so its showing the default Mono. This could be a simple case of low signal, unless the affected stations are foreign and filter the sound trap at a different frequency
Dec 14, 2015 | Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
No sound out of one of the earbuds
YOU HAVE A STEREO JACK, LOOKING AT THE EAR JACK THERE ARE 2 COLORED CIRCLES AROUND THE STEEL EAR JACK WHICH DESIGNATE STEREO, ONE COLORED CIRCLE IS MONO-ONE SIDE, IF YOU HAVE TRIED SEVERAL DIFFERENT SETS THEN YOUR EAR JACK IS NOT MAKING A GOOD CONNECTION TO YOUR STEREO EAR JACK AND ONLY GIVING YOU SOUND TO ONE SIDE(MONO), AND MIGHT NEED REPAIRED
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Mono/stereo sound
try the settings button and then hit audio and turn the sound to either mono or stereo or your speakers may be blow
Oct 19, 2008 | Akai LCT3701AD 37 in. LCD Television
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Mono/stereo flashes in upper left tv
The mono/stereo is an indicator of the audio signal that the TV is outputing. Like most car radios, they have an indicator that tells you when a station in coming in clear, which may be just an LED or a light. When the signal is weak or when your on a non-stereo station the indicator will not be on. What signal are you providing to the TV? Cable, OTA, STB output??? low RF signal level could be the cause for this.
Mar 18, 2007 | iLO 3200 32 in. LCD Television
Stereo/mono on iLo 42 screen tv
I have encountered the same problem. I have looked through the menu at least a hundred times to find an answer, but the only thing that I have been able to come up with is to push the MTS button on the remote.
Mar 12, 2007 | iLO 2600 Television
Installing PA5422 in two channewl mode
Since your first paragraph is leading to your question paragraph, I'll adress that. "what is the difference amongst the MONO/STEREO/L+R switch options available on both Front and Rear AMP X-over Sections of the PA5422?" Mono is same sound output on each channel, stereo is what you want as it gives out stereo sound, and L+R is most likely blending the channels together.
Sep 23, 2006 | Eclipse PA5422 Car Audio Amplifier
Akai LCT3701AD 37 in. LCD Television Logo
55 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
