Question about Canon EOS-AE-1 35mm SLR Camera
Zero activity with ae-1 program camera
Have recently purchased a used canon ae1 program. Being a novice I know little but wiling to learn. The problem is when the shutter release button is pressed there is nothing happening and winder lever not winding all the way and is kind of stiff. The camera looks in mint condition but not working. I have tested the battery and shows (i think) just baout enough power to give some sort of activity, ie bleeps etc, but nothing. Please any experts, any advice?
Kind regards
Alex
  • jonnysaintly Nov 24, 2008
    same problem,  put a new battery and still won't advance film, won't wind, wind does feel stiff.
    is it fixable?
  • bcseeker101 Nov 26, 2008
    My AE-1 Program Canon has been stored for about 18 years. I never really used it much. I was going through some boxes and came across my camera and got really interested in it. I installed a new battery and re-read the manual. But , as you might guess I have the same problem. The shutter won't work and I can't feed the lever. It goes about halfway. I tried seeing what might be wrong so I took of the lens and noticed the mirror was in the wrong position. I know little about the workings of the camera but I did manage to reset it by playing around with some levers inside. The shutter clicked once but when I went to advance again I had the same issue. The manual says if you store it you should take it out a few times a year and work it so the mechanisms don't stiffen up. Still looking for a solution.
    Problem Solver:
  • 13 Answers
Make sure it's set on "A" not "L".
I got a AE-1 program 2 days ago, love it to death and just replaced the battery with a 28L lithium.
Everything works better and faster now.
Make sure your battery tester beeps 5-6 per second. before I replaced my battery, it beeped maybe 2 a second.
Posted on Nov 14, 2009
    Problem Solver:
  • 7 Answers
Is there film in it ? Remove it if there is,
If not you need to take it to a repair shop nothing you can do ... KC
Posted on Apr 07, 2009
Prices ae1 canon
Check eBay or Craigslist.com for the best idea of what an AE1 is going for.
May 05, 2014 | Canon Photography
Free owners manual ae1 canon film camera
You may download a copy of the AE-1 manual here.
If you have an AE-1 Program, you may download its manual here.
Dec 02, 2011 | Canon Eos 10d 20d 30d 1v Ae1 A1 Ef Ef-s
What is the difference between ae1 and eos 50 i have ae1 lens and they they do not fit the eos 50 as i was led to believe paul.
Whoever led you to believe that is wrong. The AE-1 uses the Canon FD mount, while the newer EOS cameras use the EF mount.
Canon introduced the EOS (Electro-Optical System) in 1987. The bayonet-style EF lens mount is at the heart of the EOS camera system. Breaking compatibility with the earlier breech-lock FD mount, it was designed with no mechanical linkages between moving parts in the lens and in the camera. The aperture and focus are controlled via electrical contacts, with motors in the lens itself.
Apr 28, 2011 | Cameras
I have acquired a Canon AE-1 and an AE-1 Program SLR cameras and both of the film-advanced levers will not advance the film. Both of the levers only crank back about a 1/3rd of the way. I would like to...
This is a very common fault now on almost all AE1's and related models like the AV1.
Most of the time, it's due simply to age and dried out lubricants. The cameras need a strip down, thorough clean, and reassembly using fresh lubricants (known as a CLA service). It's wise during this process to remove and replace all light seals and mirror buffers as they'll have turned into a corrosive sticky black goo by now. The job is for professionals only due to the need for special tools and skills and the need to readjust the shutter speeds upon reassembly. Although it's not cheap (£80-£100 parts in the UK, cheaper in the USA and much cheaper in some Far Eastern countries such as Malaysia. If broken parts need replacing there is an extra charge), it's far cheaper than any new camera of the same quality and will ensure that the camera gives many more years of service. A freshly CLA'd camera has a resale value, a broken AE1 is usually completely worthless.
Aug 16, 2010 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Manual
Try Google!
I did a quick search and came up with these two links. Both have slightly different versions of the manual.
http://www.canonfd.com/pdf/ae1.pdf
http://www.butkus.org/chinon/canon/canon_ae-1/canon_ae-1.htm
Matt
Apr 26, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Aug 26, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
269 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
