Question about Singer 15ND Mechanical Sewing Machine
The bobbin is getting caught and needle is jamming
I have a bernette 65 and its a fairly new machine. I only used it a few times. I just rethreaded the machine and was doing a test run and the needle kept jamming, and it broke. i replaced the needle, and when i turn the wheel to raise and lower the needle, it seems to be ok until i raise the needle all the way, when i bring it back down the bobbin does not turn and the needle hits the plastic, its not rotating for the needle to catch. i thredted the bobbin a few times and its just not rotating properly. the first stitch i sewed pulled a chunk of thread through. i have no idea what i'm doing wrong, i've never had this problem before.
  • DillieJane Dec 20, 2008
    Only now the bobbin holder is jumping out of place. I belive the bobbin holder is now broken and needs to be replaced. This is my second machine. The first was returned and I was given the floor model. It is not any better.
  • 46 Answers
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Posted on Oct 24, 2008
Bernette deco 600 I have changed the needle, rethreaded the machine, new bobbin in and it is still not catching the bobbin thread to sew!
Do you have the bobbin in correctly? Clockwise or counterclockwise...
Is the needle in correctly? It could be backwards.
Rethread the bobbin if the thread is not wound on properly...too fast makes the thread too tight, too slow and it can wrap onto the bobbin in a haphazard way.
Check to be sure have the correct needle for your machine...matches stitch etc..
If your machine is electronic...turn it off so it goes back to any default settings.
seems like a lot, but one little thing...
Nov 24, 2016 | Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Jamming
try changing the needle
rethread the machine top and bobbin
even try a different bobbin--make sure the bobbin is turned the right
way
make sure the top thread has not come off the thread take up lever
Dec 22, 2012 | Sewing Machines
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
Needle is stalled
try rethreading the machine top and bobbin
also try a new needle
make sure that the top thread has not come off the top thread takeup
lever
clean under the needle plate and in the bobbin area for lint
Nov 30, 2012 | Brother PE770 Computerized Sewing Machine
My bernette 65 is bunching underneath. How do I resolve that?
Grasp the threads and hold them down when you start your seam. If it still happens make sure your thread is seated into your upper tension mechanisms. If that still isn't solving your problem... CLEAN between the tension discs with some sturdy fabric folded in half. (wax build up from threads can cause issues)
Good luck
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
May 10, 2012 | Singer 3323S Sewing Machine
I am getting a code that says the needle is bent or the thread is knotted, neither is true. I have changed the needle and rethreaded both the top thread and bobbin. What else could it be
I have a Bernette Deco 600 which was doing the same thing. While it was running it would jam and give this code. If you take the cover off of the end of the top of the machine on my machine there was a rod the needle was connected to. There were two cams attached to this rod, one of the cams was slipping which threw the machine into a jam. Once I pushed the cams together and tightened down the set screw it worked great. Good luck
Nov 19, 2011 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
167 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
