Zanussi ZWF14581w pumping continuously at start of cycle not filling
My Zanussi washing machine is pumping continuously at start of cycle and won't progress to fill.I suspected pressure switch but new one made no difference.Pressure chamber and tube are clear. If I **** on pressure switch very hard the machine starts filling and will continue normally with tube reconnected until it reaches the same point again
??? any hints or ideas
5 Suggested Answers
  • 1462 Answers
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
  • 19 Answers
SOURCE: zanussi zwf14581w front load washer
Are there clothes locked inside machine or water visible inside machine? Either machine has not drained eg.blocked drain hose or pump, or door lock broke .please reply.
Posted on Jun 02, 2008
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Error code on washing machine!
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
How to remove Zanussi ZWF14581W Filter - Drain Pump
Sometimes a larger object prevents pull out the filter and then is only solution to remove drain pump from the filter housing and remove the foreign object from opossite side.
26176372-mqizlhaqplgaehwd1f10tdku-3-0.jpg Dado
Apr 26, 2016 | Zanussi Washing Machines
Zanussi zwf14581w no fill wont spin only drains, how can I fix this?
EITHER BAD DOOR SWITCH OR BAD CLUTCH, NO FILL BAD WATER PRESSURE SWITCH
Mar 19, 2015 | Zanussi Washing Machines
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
Zanussi washing machine zwf14581w . err e40
Zanussi's 'E40' states 'door open, interlock, wiring or main PCB'. Hopefully it is just a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 20, 2011 | Zanussi FJ1454W Front Load Washer
Hi.
Error 40 means : "Door Error"
When you get error 40 it is usually because of a defective door interlock.
Try disconnecting power for five minutes. If the error comes back the parts to be tested are door interlock, wiring or main PCB. The defective part must be replaced. Parts and quote on repair can be obtained contacting Zanussi customer service at the number listed on the owners manual.
Regards.
Ginko
Aug 20, 2011 | Zanussi W1042W Front Load Washer
Cycle starts, continual humming, no wash, no movement, just humming noises. Have to stop the wash.
If it hums from start, and it is filling fine from inlet valve, then the problem is usually timer control board or motor control unit board/motor failure.
If it gets stuck on filling forever, check also the pressure switch.
Parts must be tested before replacement.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Zanussi ZWF12070 Front Load Washer
240v 50Hz Zanussi zwf14581w wont start code EH1 with 220v 60Hz
EH1 is a fault code that relates specifically to the frequency of the electrical supply. The power board is designed for 50Hz and will notice if it does n't get what its looking for.
You may be able to purchase a new main PCB that works with a 60Hz supply. You would need to contact Electrolux to ascertain whether this would be possible.
Nov 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf14581w front load washer
Jun 02, 2008 | Zanussi Washing Machines
The Washing Machine fills and then empties with not running a wash cycle
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
